$50 TO ANYONE WHO CAN GET MY CAR RUNNING
Old 12-12-2006, 05:02 PM
  #176
jz98ctr's Avatar
the busted fuse you have...is it just separated or black
usually if its separated it's an over-current situation
usually if it's black it's a ground out somewhere
Old 12-12-2006, 05:24 PM
  #177
API Tech's Avatar
What fuse is "like" a relay? Either it IS a relay, or it is NOT a relay.
Also, where is the fusible link you are talking about? I am lost.......
BTW, fuses do not blow w/o reason at the same time you wire something. Thats like saying "I missed 5th the other day and shifted into 1st, coincidentally a valve failed and fell into the piston, isn't that weird?"
Old 12-12-2006, 06:32 PM
  #178
luvs2spooge's Avatar
Default Re: (PnkRokCountryboy)
engine damper for anyone?
Old 12-13-2006, 12:10 PM
  #179
akandok's Avatar
iif you are just going to throw the fuse in with out checking if the wiring is ok, make sure you get a couple
Old 12-14-2006, 03:01 AM
  #180
PnkRokCountryboy's Avatar
Default Re: (akandok)
the fuse fixed the voltage problem. but im still having the exact same issue.
Old 12-14-2006, 05:26 AM
  #181
jz98ctr's Avatar
i was just thinking....you have an obd2a car....you now have the right conversion harness (obd2a to obd1 correct)? but yet you still have the dizzy wired for obd1 as well correct?...hmmm i thought when you use those conversion harnesses there is no need to rewire the dizzy too....sum1 correct me if i'm wrong
the swaps i've seen were from same year and always vtec so i'm prolly wrong here
also...where along the harness does this fuse go...close to the ecu or firewall cuz i've done a couple cars and i don't remember seeing a fuse or fusible link along an EK harness before
Modified by jz98ctr at 9:38 AM 12/14/2006
Modified by jz98ctr at 9:40 AM 12/14/2006
Old 12-14-2006, 06:12 AM
  #182
Default Re: (jz98ctr)
Yeah, i am using the correct ecu harness. I am using the OBD1 dizzy because i found one for a good deal. So i repinned it for OBD2 due to how simple it was to do. and I've reched my wiring twice. It has to be somethnig to due with my ingition ("rywire") .
There's an underdash harness as you all know runs from my ignition switch to the relay. there's a harness that breaks off of that harness and runs underneath the Under hood fuse box. one Plug Connects in to the "IG1" Ignition fuse.
Old 12-15-2006, 07:43 AM
  #183
API Tech's Avatar
Did you ever diagnose why the main relay is not powering up the fuel pump? Is the fuel pump still jerry rigged w/ a switch? Shoudn't you repair a KNOWN problem before you get ahead of yourself?
#1 repair: Sell it and buy a Honda. Ohh, you already have a Honda.....guess your screwed
Modified by API Tech at 9:54 AM 12/15/2006
Old 12-17-2006, 09:14 PM
  #184
jz98ctr's Avatar
well i hoped you did the right thing and disconnect the battery first before any services were done. but did you have anything on when the battery was disconnected....maybe the ignition was on when it was re-connected it might cause a spike in the current real quick in order to pop the fuse. **** fuses have popped from getting a jump-start or hooked up to battery chargers
wierder **** has happened
Old 12-17-2006, 09:27 PM
  #185
jz98ctr's Avatar
hey... just check the very last post on page 1 and how about the middle of page 4.......when i told you to check all your fuses with a meter????
i think you might owe me $50......i take MO or cash...cash is always preferred
Modified by jz98ctr at 1:46 AM 12/18/2006
Old 12-17-2006, 09:30 PM
  #186
djsire's Avatar
Default Re: (API Tech)
i had a similar problem to this ont to long ago.
turned out that my tranny to body ground was loose.
i thought it was tight when i checked by hand.
the relay would click. and nothing would happen.
the i broke out a ratchet and noticed it wasnt titght at all.
after tightne ing.
the car started right up and never had a problem scince.
tegdude227
01-31-2009 03:59 PM
PnkRokCountryboy
12-07-2006 05:20 AM
PnkRokCountryboy
12-05-2006 05:14 PM
MarkAngelo
05-18-2004 03:51 PM
Quick Reply: $50 TO ANYONE WHO CAN GET MY CAR RUNNING
