Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Random Sputtering and Backfires
Old Dec 19, 2024 | 04:54 PM
DasilvaFB6's Avatar
Default Random Sputtering and Backfires
Car Setup
Boosted 2013 Civic Si
I have a full Maxspeed kit, RBC, including a new 6262 turbo, Stage 4 Action clutch (unsprung) with a lightweight flywheel, and a rebuilt Gear X transmission. The car was already boosted before the transmission blew, and it was running perfectly with no issues. After blowing the transmission and upgrading the clutch, turbo, and transmission, I started experiencing a really bad sputtering issue.
Symptoms:
  • The car bogs badly on cold starts. The idle fluctuates up and down before stabilizing, and it backfires during the cold start idle.
  • While driving in this temperature range, the car backfires heavily and sputters.
  • Excessive backfiring with pops and bangs occurs during deceleration or when feathering the throttle.
  • The car backfires and feels off when shifting gears.
  • When downshifting to second gear, the car bogs as if fuel is being cut off and then suddenly restored.
Additional Info:
  • No CEL codes are present, though I do get a P0128 in the morning, but I don't believe it's related to the issue but i could be wrong.
  • The VCT has been cleaned after noticing the cam and command weren’t hitting their target.
  • The injectors have been cleaned, and no issues were found with them.
I have contacted my tuner and he is a very reputable tuner, and we have been over couple logs trying to figure out what the problem is. I do have datalogs that i can send also.
Honda1664
Honda Civic (2001 - 2005)
Oct 1, 2021 05:52 AM
EddieHatchBlack
Aug 15, 2005 07:25 AM
abeaujuin
Jan 4, 2004 07:12 PM
Import RP
Mar 21, 2002 11:05 PM
