Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Civic A/C problem
Old 04-15-2016, 03:40 AM
jmerritt10340's Avatar
Default 2007 Civic A/C problem
A/C compressor has been replaced pulled a system vacuum and charged. All fuses under dash and under hood are all good. Replaced clutch relay. Ran the HVAC self-diagnostic no DTCs. A/C light comes on but no fans or compressor. Fans come on at high speed when engine temperature rises, so fans are working. In looking at the wiring diagram of the system the evaporator temperature sensor might be the problem. Any way to bypass before having to pull the evaporator to get at it? Have energized the compressor at the three wire connector and compressor runs fine.
Old 04-15-2016, 07:14 AM
W95 gives me a hard-on
foumer's Avatar
Default Re: 2007 Civic A/C problem
how many wires go to the sensor? If its a wax type temperature sensor its basically a switch. So just jumping the two wires at the plug might do the trick.
Old 04-15-2016, 07:59 AM
b16racereg6's Avatar
The plug from the compressor and thermal switch was having a bad connection on my car ac would work then stop I replaced everything like you. I then played with that plug and found out it was faulty so I pinched it closed with a zip tie and my car has ice cold ac 06 ex
Old 04-15-2016, 09:39 AM
fcm
Old Fart
fcm's Avatar
Evap. switch can be jumped, but do not leave it jumped, evap. will freeze up, replace it if it's bad. 94
Old 04-15-2016, 01:15 PM
Thanks for the responses. Thermal switch is new with the compressor. I am going to try and jumper the evaporator temperature sensor but am trying to locate the connector. Is it the white two wire connector behind the glove box?
Old 04-15-2016, 04:55 PM
holmesnmanny's Avatar
The evap temp sensor will normally only fail to the point that it doesn't shut off the compressor when the expansion valve fails and the evaporator freezes over. It's not likely it's preventing the compressor from coming on. Without looking it's possible you can atleast test it for continuity before trying to replace it.
Old 04-16-2016, 06:10 PM
fcm
Old Fart
fcm's Avatar
I have replaced more then a few evap temp sensors, in Honda/Acuras because of open circuit.
Yes it is the two white leads. 94
Old 04-17-2016, 01:13 AM
He will know by jumping the switch and testing the sensor.
Old 08-09-2016, 03:52 AM
Replaced the pressure sensor switch, system has 80 lbs of pressure. No A/C or A/C condenser fan. All fuses are good replaced both A/C and A/C condenser fan relays but neither will run when A/C switch is pressed on dash. After metering circuits, looks like no ground from PCM being provided to relays. Circuit diagram shows pressure switch, evaporator sensor, coolant temperature sensor, all are good. Blower runs fine.
Old 08-12-2016, 05:23 AM
Are there any circuit diagnostics I can do before I have to tear into the dash to get at the HVAC Control Unit 24 pin connector and follow the diagnostic routines in the book?
Old 08-12-2016, 03:14 PM
Civiccity03's Avatar
Let's get some visuals on these threads. It really helps out people reading.
Old 07-12-2022, 06:05 PM
ns197's Avatar
did you ever fix your issue I’m having the same issue
Old 07-13-2022, 05:30 AM
Turned out to be a bad compressor thermal protect
eschavez6
Honda Civic (2001 - 2005)
08-07-2018 08:16 AM
akb427
06-28-2013 08:51 AM
dohcFTW
04-22-2008 11:10 AM
97civic123
05-27-2006 05:50 PM
Quick Reply: 2007 Civic A/C problem
