Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 civic no start.. mothers car
Old 04-16-2018, 03:53 AM
EJ8CIVIC's Avatar
Default 07 civic no start.. mothers car
ok this my first time working on these 07+ civic’s
my mothers civic Lx battery and atlenator quit on her had very hard start up then died,
went to walmart they charge the battery came out it had a dead cell.. bought a new one, went home replace it and car wouldnt start so moved onto the altenator, then replaced it.. hopeing all was good.. nope..
so sum it up new battery and altenator it dose nothing as if it has a dead battery again, doom light is dim..i check the battery its got 12v..
what is going on.. need help guys
Old 04-16-2018, 03:42 PM
97emsedan's Avatar
Default Re: 07 civic no start.. mothers car
Battery posts clean, connectors without corrosion? The battery should be allowing full starting power. the only other thing I can figure is that the security system such as the engine immobilizer is preventing the car from starting.
Old 04-17-2018, 05:56 AM
I'm not Rick!
rick_rabies's Avatar
you can always start a car with no alternator keep that in mind. but battery would soon die.
any CEL?
you could have 12v but low amperage. get battery checked...buy brand new. does it start if you jump it?
Old 04-17-2018, 12:06 PM
MyAcc0rd's Avatar
I no longer buy walmart car batteries bc I've had so many of them die within months of purchase. If it's your starter, so sorry. Fck that job, it's a major PITA!
Old 04-17-2018, 06:59 PM
EJ8CIVIC's Avatar
dude i took the starter out and yes it was a Fck job.. took it to autozone they tested it and pass.. took it back hone reinstalled it and car FREAKN started up..
so i got new battery/ alt now..
have no clue what the deal was
Old 04-18-2018, 04:56 AM
I'm not Rick!
sounds like wire/cable issue being intermitant.
I would get some good grounds. extra grounds. and put new battery terminals on. clean the terminals on the starter. good for another 40k miles
Old 05-02-2018, 07:50 PM
EJ8CIVIC's Avatar
Ok guys i need more help..
car finally gave out tiday.. i did some goodo love taping on the starter and fured up..
so bought new starter today and started good.. i shut it of and came back 5-10mins later i got nothing.. no crank, no start.. dash like all cone one..
really geting mad now
new battery, alternator, starter .. im totally stumped now
Old 05-03-2018, 12:30 AM
holmesnmanny's Avatar
do you have an aftermarket alarm ?
Old 05-03-2018, 03:29 AM
EJ8CIVIC's Avatar
no sir.. factory alarm..
when i put the key in the green light flashes and goes away, so from what i understand the immobilizer is working as it should..
Old 05-03-2018, 04:51 AM
I'm not Rick!
what this guy said.
check for ignition failure. (key in car on. jiggle steering column, key, if it shuts off bad ignition)
or main relay. all this work and checking is free.
either way I would resolder main relay just to refresh it
Old 05-03-2018, 06:18 AM
EJ8CIVIC's Avatar
what this guy said.
thanks ill check today after work.. i cant even get it to turn over though..
Old 05-03-2018, 08:00 AM
I'm not Rick!
ok I reread the whole thread. sounds the whole issue is starter/cable issue.
still though. connections needs cleaned. is this car manual by chance?
do you get a solid click though when you turn key and it doesn't start?
starter signal wire popped off starter? power cable tight and clean on it?
maybe pics
Old 05-03-2018, 09:31 AM
EJ8CIVIC's Avatar
maybe pics
moms civic is auto..
as for a click i dont recall hearing a click noise..
signal wire is good/tight.. power cable to starter is tight..
battery terminals are really tight
Old 05-03-2018, 09:37 AM
I'm not Rick!
starter relay. you have others like it. swap them out in the fuse box. could have fualty relay.
but it def sounds starter related. too bad you live far away.
Old 05-03-2018, 02:15 PM
Hysterically Calm
TomCat39's Avatar
I notice question present about the alarm....
I did not see if anyone asked if you put the key to the on position when you connected the battery.
Most immobilizers require the key in the ignition and in the on (running not cranking) position when you connect the battery, anything else is considered a security bypass attempt and does not disarm the security.
Old 05-03-2018, 02:49 PM
EJ8CIVIC's Avatar
no i didnt put the key in (on position).. are you saying that i should disconnect battery (first) then put key in ON position then connect the battery..?
Old 05-03-2018, 02:53 PM
EJ8CIVIC's Avatar
i can try that.. sorry for the big picture.. which one would be the starter relay?
Old 05-04-2018, 09:53 AM
Hysterically Calm
TomCat39's Avatar
Yes, I would try that to rule out the security system causing you issues.
Old 05-05-2018, 03:32 PM
EJ8CIVIC's Avatar
ok i tried your way and still had no luck..
i aslo just replaced (5-5-18) the igniton switch sensor and and still no luck..
only time i have luck is when i disconnect the battery and reconnect battery itll start up.. but the second i turn off and TRY restart nothing happens.. even with me wiggling the key on start up nothing happens..
also i put my fingers on the relays (underdash) and each relay clicks when i turn the key over tryn to start
Old 05-05-2018, 03:59 PM
the starters on these things are notorious for going out before 100k, especially if it's an automatic
Old 05-05-2018, 04:09 PM
EJ8CIVIC's Avatar
starter is new reman from advance autoparts..
Old 05-19-2018, 05:43 PM
hondaslave1342's Avatar
I seen on youtube about a ground point under the air cleaner that was bad..i just changed the starter in my 08..suckkked..also someone plugged a scanner in and just being connected it started but without it it did nothing..
specbb6
06-24-2012 03:07 PM
Diet coke boii
09-30-2007 09:15 PM
W O T
05-08-2007 10:36 AM
LaOstha
17
02-21-2005 02:15 PM
my ride
07-21-2004 10:40 PM
Quick Reply: 07 civic no start.. mothers car
