Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
rattling when accelerating
Old 02-16-2011, 06:54 PM
QueizaG's Avatar
Default rattling when accelerating
I have an 01 civic lx coupe standard transmission that i just got today, and when i accelerate there is a rattling noise mainly in 1st, 2nd, and 3rd, no vibration or anything just the rattling like somethin is loose, i hope its not the transmission, please help...thanks in advance
Old 02-17-2011, 04:21 AM
Sanji
toyomatt84's Avatar
Default Re: rattling when accelerating
It might have been an exhaust shield. Have you looked under the car yet?
Old 02-17-2011, 07:28 AM
QueizaG's Avatar
i've read that it could be that alot of place cause it sounds like it comes from the right side of the car, so i will check can u tell me what im looking for cause i dont know what it is
Old 02-17-2011, 07:39 AM
QueizaG's Avatar
i just looked up there and i dont think it even has a heat shield i could be wrong but i need to jack the car up so i can see for sure
Old 02-18-2011, 10:08 AM
Plead da Fif
It Wasn't Me's Avatar
Does the car make any hissing / grinding / chattering noises while in Neutral and your foot off the clutch, and does that noise go away when you push the clutch pedal down?
Does this rattle only occur while accelerating, or does it do it while you're parked and revving the engine, too?
Old 02-18-2011, 10:20 AM
QueizaG's Avatar
only when accelerating and decelerating, after the car is running for a while it goes away sometimes, but it doesnt do it when its in neutral or when the clutch is pushed in, if im accelerating and then push in the clutch the sound goes away, i heard it might be the input shaft bearing
Old 02-18-2011, 10:56 AM
Plead da Fif
Sounds like it is most-likely the culprit.
Old 02-18-2011, 10:59 AM
QueizaG's Avatar
what is the culprit, and how soon do i need to get it fixed also how much does it cost, thanks
Old 02-18-2011, 11:10 AM
Plead da Fif
what is the culprit
As soon as possible.
I don't know. You'll need to contact your local repairman for that. (dealership, or independent shop)
Old 02-18-2011, 05:18 PM
QueizaG's Avatar
i feel retarted smh, you were saying that the input shaft bearing is the culprit haha thanks for your info
Rva802
01-08-2013 08:11 AM
kr1s79
05-20-2003 12:06 AM
geminis2k
01-28-2003 01:27 PM
hardcore
08-19-2002 05:29 PM
Amidala
02-21-2002 05:54 PM
Quick Reply: rattling when accelerating
