How long does it take to take you guys to change the Timing Belt?
I have done timing belts before, a long time ago on my B16 CRX and more recently on VW's/Audi's so I have experience doing it. How long does it usually take you guys to change the belt, pump, and tensioner.
The Civic is a DX so non-vtec if that matters.
Thanks.
Thanks.
Re: How long does it take to take you guys to change the Timing Belt?
an hour or two if you know what your doing and have all the tools right there
It's best to plan on spending the day doing it. You never know what other kind of "problems" you may run into.
I can't count the times I've ended up spending an entire day on something that should have only taken a few hours. Something's seized, something breaks, something strips.. .. there always seems to be something.
Just did this yesterday. It took me all day. I had to replace the crankshaft oil seal there was a lot of oil down there so that ate up some time. Also my lower timing belt cover had a big crack in it and fell apart when I took it off So I had to run to Honda to get a new one.
Like the guy above me said. Just plan a day. Something will hold you up.
GDD Member
About an hour for Accords/Civics/Integra with waterpump on D/B/F/H series engines.
Hour and a half for Accord V6.
Two hours for Accord V6 with waterpump
Audi 1.8T 3-4hrs. with waterpump
Audi 3.0 4-5hrs. with waterpump
Audi 2.7TT 4-5hrs. with waterpump
VW 1.8T 45 minutes with waterpump
VW 2.0 45 minutes with waterpump
only thing that ever held me up was the crank pully bolt - use a decent impact gun & a short extension, should zip it off. if your gun's no good, you can pick a decent Ingersol rand at a pawn shop for $40 or so.
this guy has had my car since fri its now tue well I give him 1 day for paets and just 1guy.i added fuel filter & oil change
Campee
05-04-2005 10:05 AM
