Timing Belt?
Timing Belt?
I have a 96 Civic, approaching 180K
When do I need to change the timing belt again?
Second question.....I have a small exhaust leak near/at the manifold....when the car warms up it's gone. Is this something to worry about?
Thanks
Rick
Thanks
Rick
Re: Timing Belt?
should be changing the belt for the 2nd time, i was always told the belt was for 90k but of course it can last longer and maybe not even as long
Re: Timing Belt?
I'm pretty handy......I'm not as young as I used to be but....I can still turn a wrench....Last week I changed out an CV axle on the wife's van.
Should I plan on replacing the waterpump at the same time?
Thanks
Rick
Thanks
Rick
Re: Timing Belt?
ya, definitely do the waterpump too.
changing the timing belt can be a pain in the neck, especially the first time, and it is a little scary because messing up can be very costly. just be sure to follow the steps PERFECTLY and then check and recheck all of your work.
and then check again
Re: Timing Belt?
It wouldn't be a bad idea to replace the thensioner either. I usually do every other timing belt change. Nothing is worse than replacing the belt and a few months later the tensioner fails and you're back two steps. I've seen it happen enough.
Re: Timing Belt?
Re: Timing Belt?
get the timing belt kit where it comes with a new tensioner water pump and gasket
they run for about 100 or 150 i forget
if you know what you doing takes 20-30min or hours if you dont
https://honda-tech.com/forums/showth...ht=timing+belt
thats one place that does it do a search for others
Re: Timing Belt?
Re: Timing Belt?
Or he's using air tools and does it a bunch. A friend of mine said that Honda techs can do a head gasket in 15 minutes. Apparently some people can pull a motor in like half an hour.
Re: Timing Belt?
i change my timing belt once a year due to the fact i don't want my investment going down the drain cause of a stupid timing belt
Re: Timing Belt?
also on ur exhaust leak those cars crack manafolds all the time
