Time to change the timing belt
oK say i have no way of knowing how many miles are on my car... how will i know if i need to replace the timing belt... visually speaking.
Re: Time to change the timing belt (VTECTIME)
sometimes you can see hairline cracks. if there are any, time to change it
[Modified by locass316, 2:25 AM 1/13/2003]
Solbros Owns Me
if there are any obvious wear marks or tears. But, usually timing belts don't show when they are about to break, they just will. If you don't know, might as well replace it.
Re: Time to change the timing belt (Emerica)
Dont take the chance change it and the water pump while you have it that far torn down, might as well replace the Alt. belt, A/C belt, and P/S if you have these as well. A well maintained motor is priceless!!
Re: Time to change the timing belt (HondaGSR)
changed all that when i did my swap
Re: Time to change the timing belt (Jawad)
supposed to change them at 65,000
the timing belt is not somthing to neglect. if it breaks
so does your motor.
ive seen it happen. not pretty. not happy people eithre.
so does your motor.
