Tint removal help!!
Re: Tint removal help!! (delsol8694)
fully spray the inside of the window with windex, get a big black trash bag and make it 2 pieces, lay the one half on the entire inside of the window, do the same to the other side, let it set out in the sun for like a good 45 mins, then take off the trash bag, and peel a corner of the tint with your finger nail or a razor blade and pull it off, should come right off, use some type of adhesive remove and a rag to get the rest of the remaining adhesive from the tint.
sorry for the clutterness
1 Post
Re: Tint removal help!! (will7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by will7 »</TD></TR><TR><TD CLASS="quote">i take tint off all the time..i use glass cleaner and a razor blade</TD></TR></TABLE>
that's how my tint came off.
Re: Tint removal help!! (jcarothers)
did it come out clean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcarothers »</TD></TR><TR><TD CLASS="quote">
that's how my tint came off.</TD></TR></TABLE>
Re: Tint removal help!! (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy »</TD></TR><TR><TD CLASS="quote">did it come out clean?
yup, it did for me, I used the same method
1 Post
yep... very clean. it's time consuming as **** though.
soapy water and razor blade is all you need. Tint is two layers, the 1st layer rips off clean, but it leaves behind an adhesive. Keep the window wet with the soapy water and just cover every inch with the razor blade. Doesn't take too long, an hour or so for the whole car.
Spicylikcajun
05-20-2007 08:58 AM
