How do you remove window tint?
Old Aug 1, 2003 | 08:39 AM
integra15's Avatar
Default How do you remove window tint?
I need help here, this tint is stuck on really well. I need some pointers, or is there any special way to get it off easily?
Old Aug 1, 2003 | 08:45 AM
tilt's Avatar
Default Re: How do you remove window tint? (integra15)
razor blade, 3M adhesive remover, Simple Green household cleaner (in lieu of ammonia), black trash bag.
cut out the trash bag in the shape of the window, spray down the window with simple green put the trashbag over it. it will stick. Let it sit in the sun, the longer the better. Grab the razor blade and peel off enough to get it going. The film should be easy enough to peel off you can continue using your hands. If you are good, it should come off in one or two huge pieces. spray down with 3m adhesive remover (or use simple green, 3m works better imo) and wipe off the tint residue.
Use this technique on the door windows first, then you will be more prepared to take on the rear tint with the defroster lines.
DB8_TEG's Avatar
Use a heat gun an heat up a small area then start peeling the tint back. This should warm up the glue enough so you can peel it off. You will likely need to put some elbow grease to remove the left over glue and anything else left by the tint.
Old Aug 1, 2003 | 08:59 AM
obsidianG35's Avatar
Use a tint glue remover
http://www.prowax.com/1prod_bulls/c64pb.html
Old Aug 1, 2003 | 09:16 AM
95TEG's Avatar
Default Re: How do you remove window tint? (r4integra)
Have patience, its a pain in the *** if you dont. Take your time and good luck.
Old Aug 1, 2003 | 09:29 AM
andrew dc's Avatar
Default Re: How do you remove window tint? (95TEG)
i used goo gone to remove my gunk
Old Aug 1, 2003 | 11:06 AM
integra15's Avatar
Default Re: How do you remove window tint? (andrew ef)
Thanks for all the help
Old Aug 1, 2003 | 11:56 AM
quikB18B's Avatar
I took mine to a local tint shop they did it for $35 took them about 1 hr, cleaned and everything. I didn't feel like messing with it .
Old Aug 1, 2003 | 12:07 PM
fivespeedintegra's Avatar
Default Re: How do you remove window tint? (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">I took mine to a local tint shop they did it for $35 took them about 1 hr, cleaned and everything. I didn't feel like messing with it . </TD></TR></TABLE>
that's what i'd do....that way, they're liable if something goes wrong.
Old Aug 9, 2003 | 12:21 AM
aznfab's Avatar
it cost 35 bucks for them to remove all the tinted windows...or juss one? how many did u get removed....
Old Aug 9, 2003 | 12:28 AM
Dc2 Powered's Avatar
try using a hair dryer to melt down the glue so it would more easily come off.
1993ludevtec
Mar 22, 2004 03:19 PM
JdmLsPwr425
Mar 10, 2004 07:34 PM
quik2kSi
Jan 3, 2004 11:32 PM
USDMMARK
Apr 25, 2003 07:18 AM
gokuson
Jun 21, 2002 01:24 PM
