♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Old 02-29-2012, 02:51 AM
  #32201
DarryCar's Avatar
Default Re: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
What size cable are you running from the battery to the front of the car? I ran 8 gauge to the front of my car and it did all kinds of weird ****. I was also running a 100 amp fuse to the starter that it kept blowing. I took out the fuse and ran 4 gauge wire. Never had another problem.
Old 02-29-2012, 04:03 AM
  #32202
R boy fresh's Avatar
Originally Posted by spAdam
If you didn't have a clean metal to metal contact on your battery ground it may have arced a bit when you pulled starter current through it and oxidized the connection and/or burned the paint right there, making enough resistance to render the circuit open. It happened to me once. I would start at the battery ground since everything went dead.
Old 02-29-2012, 05:36 AM
  #32203
93egallmotor's Avatar
thanks, ill check all the crap out today, getting the windsheild installed as we speak though. gotta wait till this tool is done messing with the car lol....and im running the same setup ive done on 3 different tucks so i know the 4g im using isnt the problem
Old 02-29-2012, 05:39 AM
  #32204
spAdam's Avatar
Also, I noticed you mentioned checking the main battery fuse. If you have the battery in the trunk you really should have a fuse or breaker (I prefer breakers) as close to the positive terminal of your battery as possible.
Old 02-29-2012, 07:52 AM
  #32205
BINGO!.....i sanded the paint under the neg terminal till it was greyish, which i thought was the bare metal. but turned out to still be primer. so i sanded all the way through and she fired up on the first try!....thanks to everyone that helped. love this thread!
Old 02-29-2012, 09:11 AM
  #32206
spAdam's Avatar
Old 02-29-2012, 12:23 PM
  #32207
Who the fack changed my title?!
sh!ft's Avatar
Originally Posted by Jaypayne05
just a pic with the turbo manifold and turbo install. not done yet need to clean up some wires and install my AC condenser and compressor
where can i get hoses like the ones above in this pic for my catch can??
Old 02-29-2012, 01:57 PM
  #32208
spAdam's Avatar
www.anplumbing.com
Old 02-29-2012, 02:41 PM
  #32209
sh!ft's Avatar
that looks like a rubber made hose, i did not see that on that web site...or maybe i missed it.
Old 02-29-2012, 03:02 PM
  #32210
spAdam's Avatar
Might be push on hose. Pointless to use full swivel seal ends and hose on crankcase ventilation system (except for bling blang), it shouldn't be carrying any pressure really.
The push on hose is about 1/2 the price/foot of Pro-lite, for example. Fittings are about the same price. I've used it on dry sump lines with zero leakage from the fittings, btw. Hose is still rated to 250psi working (Aeroquip FC332)
Old 03-01-2012, 06:19 AM
  #32211
loverface's Avatar
Originally Posted by My_EFsedan
finally going to just post in here.
flip the booster for a cleaner look
Old 03-01-2012, 08:45 AM
  #32212
efcivic317's Avatar
is everyone using metal glaze instead of bondo for the bays?
Old 03-01-2012, 11:46 AM
  #32213
SlimBB4's Avatar
I am using Evercoat Metal Glaze. I am also using USC Icing (I think thats what it is anyways).
_zac
Old 03-01-2012, 11:51 AM
  #32214
The G2 Racer's Avatar
Evercoat products FTW!
After using a good quality product you will never touch bondo again.
Old 03-01-2012, 11:59 AM
  #32215
Jaypayne05's Avatar
its rubber hose that i got form a place in orlando by the name of amazon hose
Old 03-01-2012, 12:49 PM
  #32216
hb420's Avatar
Originally Posted by Corey R
Iv searched plenty, anyone can point me to 2nd Gen Teg firewall harness plugs.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old 03-01-2012, 03:26 PM
  #32217
spAdam's Avatar
I know exactly where that place is! My old band used to practice right across the street...
Old 03-02-2012, 05:00 AM
  #32218
OhShift!'s Avatar
Hey guys, I'm going to begin tackling my engine bay this weekend.
A couple of the connectors on my wiring harness are broken, and I was looking to replace those with new units. I've tried googling but can't seem to find anywhere that sells honda replacement connectors.
Anyone know of a place? I'd rather not junkyard it up because I'd like to redo all the plugs to be new.
Thanks!
Old 03-02-2012, 05:58 AM
  #32219
spAdam's Avatar
Www.newunitedracetach.com
Old 03-02-2012, 06:59 AM
  #32220
mikercp's Avatar
www.newunitedracetech.com
Old 03-02-2012, 09:27 AM
  #32221
My_EFsedan's Avatar
thanks. probably going to do that today since the head isnt on and the dash is out.
Old 03-02-2012, 09:42 AM
  #32222
spAdam's Avatar
Originally Posted by mikercp
Oops. Phone typing owned me.
Old 03-03-2012, 06:10 PM
  #32223
loverface's Avatar
got my inline fuel filter in today and mocked up set up real quick to realize i forgot to buy one fitting lol
doesnt matter what end the filter is on right?
Old 03-03-2012, 06:24 PM
  #32224
sc34dc4's Avatar
Correct. You can either run it right off the rail or down by the metal feed line and anywhere in between. Just make sure the flow is going in the right direction and you're set.
Old 03-04-2012, 06:55 AM
  #32225
siblues's Avatar
Hey any of you guys with a tucked rad in an ek feel like answering a few questions for me.I just need to know what fittings you used to make the rad hoses so I can place my order ahead of time.
Quick Reply: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
