♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Old 03-04-2018, 02:51 PM
  #35376
Former Moderator
B18C5-EH2's Avatar
Default Re: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Got the dented shock towers fixed. Needs clear coat...
Old 03-09-2018, 08:46 PM
  #35377
grayz221nyc's Avatar
nice bays. but why do most of you guys take out the A/C and ABS and the POWER STEERING
Old 03-10-2018, 05:00 AM
  #35378
Former Moderator
B18C5-EH2's Avatar
People remove that stuff usually because:
A. A lot of these cars didn't come with power steering, but if they did getting rid of it can clean up the bay.
B. Most of these older Hondas' A/C systems don't work anyways, so instead of trying to troubleshoot that and have the lines and other A/C related **** clogging the bay people choose to get rid of it.
C. Not a lot of these Hondas came with ABS, especially if they were Civics. ABS lines aren't pretty either, and crowd the bay.
If you're going through the trouble to relocate brake hard lines, fuel filter, weld up/smooth out all the extra bolt holes, etc. then why would you WANT all the accessories cluttering up the bay?
Having said all that my car has A/C, P/S, and even cruise. The A/C lines are not as well hidden as I'd like, but I don't care enough to get new lines made. My P/S set-up is not a conventional belt-driven Honda pump, but a hydraulic-electric motor driven pump from the second gen Toyoya MR-2, and it's even on a toggle switch to turn it on/off as desired. Cruise is tucked under the windshield cowling. My car never has ABS, so...
Old 03-11-2018, 08:13 AM
  #35379
JustinHis4Honda's Avatar
doing a GSR swap into my EG and I want to do a mild wire tuck (ground cables, batt. relocate, and harness from both sides of bay) to start off with.
I have pulled the old D series motor and now starting prep to paint the bay next.
my ? is... should/can I tuck now while the engine bay is open and before paint? Or would it be better to do all tucking after the "new" engine is in and running.
I'll be painting the bay myself but having a shop to the GSR install. I'm unsure if a tucked bay will be problematic for the shop swapping in a non native engine (albeit just a D to B series swap)
just thinking about trouble shooting issues, ie: not knowing if its the swap or tuck causing whatever problems that might pop up.
Old 03-19-2018, 04:49 PM
  #35380
djrockytharp's Avatar
Because race car man. Maybe I'm just getting old but I specifically bought my 99 ek hatch because it had working p/s and a/c. I think it would be cool if somebody would figure out a way to do tucked a/c lines with a/n fittings and ****. Instead of just ripping **** out.
Old 03-21-2018, 08:06 AM
  #35381
ddwelch's Avatar
Attachment 513572
Old 04-02-2018, 09:18 PM
  #35382
HondataB18's Avatar
Instagram- Cpanchoo
Old 04-04-2018, 11:11 AM
  #35383
WeakSi's Avatar
Looks great
Old 04-04-2018, 11:49 AM
  #35384
Former Moderator
B18C5-EH2's Avatar
I've got all the comfort features and a shaved/tucked bay. The only thing I could do long term would be to better tuck the A/C lines, like under the frame rail. The A/C has been charged for about three years now though, so I'm not in a rush to mess with it since it blows ice cold.
Old 04-10-2018, 08:23 AM
  #35385
greg677's Avatar
Wow these bays definetly have their A game showing. Awesome work! Definetly takes time to pull off but the end result is perfect :D
I have an odd or stupid question depending on which way you look at it, doesn't hurt to ask as I couldn't really find much info about it / people actually doing it so this question might help others out too.
Q: Could you use an oil / transmission cooler as a radiator?
My answer / additional info to the question
I have a del sol and instead of going down the prefabbed tucked radiator route eg. like rywire's one I was thinking of just using one or two 30 row coolers with fans on them, would it provide sufficient cooling on a stock B16?
As for filling I would be getting the K-Tuned Upper Coolant Housing W/ Filler in a -12AN fitting. The coolers have welded -10AN fittings so which means i'll also grab the reducer fittings so everything hooks up.
As for draining just mounting the coolers with the fittings facing towards the ground shoud do the trick just unscrew one fitting and BLAM! coolant gushing out
If such a setup like this is possible you can get VERY creative on where you mount the coolers. Depending on the hose length an electric pump might also be required, rads underneath the car cough cough
So yeah just wanted to see other peoples opinions on this odd idea. Thanks!
Old 04-10-2018, 10:17 AM
  #35386
HT's TOP CHEF
Chef Andre's Avatar
After man years I can finally post something in this thread.
Old 04-10-2018, 06:25 PM
  #35387
spAdam's Avatar
Good to see you're still at it Chef
Old 04-11-2018, 04:07 AM
  #35388
HT's TOP CHEF
Chef Andre's Avatar
Thanks man!!
Old 04-24-2018, 07:12 PM
  #35389
B00stedb16's Avatar
Should have some good before and afters of mine soon.
Old 04-24-2018, 07:48 PM
  #35390
footwork mastery
.Grimace's Avatar
x2 looking good! Wish I kept my crx but the new car is more my style.
Old 05-18-2018, 07:09 AM
  #35391
Chuck Smith's Avatar
So I’ve decided to clean up my engine bay some and mess around with a wire tuck. Can someone please point me in the right direction as far as reliable sites to buy harness heat shrink from please.
Old 05-18-2018, 09:20 AM
  #35392
spAdam's Avatar
Wirecare.com
prowireusa.com
Old 05-26-2018, 05:26 PM
  #35393
Working on my tuck on a 98 Ek now. Once removing the charcoal canister, what do you do with the fuel line running to it?
Old 10-03-2018, 07:26 AM
  #35394
ylp
ylp's Avatar
Anyone know a part # for the ac drain hose firewall grommet if there is one?
Old 02-05-2019, 10:20 AM
  #35395
gorillaglue#4's Avatar
Nice picture of the part numbers man
Old 05-31-2019, 09:07 PM
  #35396
DialedLife's Avatar
Got a couple questions for you guys.
Ive been messing with the bay on my civic with a stock y7
Im taking out the heater core, and i was wondering exactly how you loop the lines?
I know the part number to cap the line from the block. 12208-pr3-000
But what do i do on that back of the thermostat?
Just cap off line 2 or something?
Also doing a fuel filter tuck. What is the part number to adapt the stock fuel feel from the rail to an? ive heard it was 12x1.5 to -6 male.
What size adapter can i use to do the the fuel return?
Old 07-28-2019, 01:14 AM
  #35397
bks84's Avatar
Who offers firewall plugs for EG's that acutally fit? I ordered the fuel tuck'd "kit" for $90 and the only one that was usable was the AC evap plug. Preferably not downstar, as Im not a huge fan of logos.
Old 07-28-2019, 08:51 AM
  #35398
You dont cap anything coming off the engine you run the heater outlet from the head to the outside port on the thermostat.
Old 07-28-2019, 06:14 PM
  #35399
Steve at Heart
Bently_Coop's Avatar
Honda makes factory rubber plugs. Check the link below.
https://honda-tech.com/forums/honda-...art-s-2223743/
B365ir
Paint and Body
129
08-28-2014 04:35 AM
campbuds
10-26-2004 01:14 PM
SOHC_MShue
27
08-22-2004 08:50 AM
yusoslo
57
04-13-2004 06:05 PM
im sabah
05-27-2003 08:48 AM
Quick Reply: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
