Nasty carbon fiber hood
Ok I posted this in my cars section but was told to post here for better results. Basically my carbon fiber hood is starting to look all cloudy towards the middle of it. I've waxed it a few times and nothing I bought a buffer and Figured I would try giving that a shot. Does anyone have any ideas or has this ever happend to you. Please help I don't want to have to buy another hood.
Re: Nasty carbon fiber hood (5genprelude)
Contact carbonall he has alot of experience with CF and Kevlar.Sometimes you can take it to a bodyshop and have them wet sand it and reclear it but it depends on how bad it is?Who made the hood my guess is vis they suck and so does their customer support
Re: Nasty carbon fiber hood (nathanong87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 »</TD></TR><TR><TD CLASS="quote">pix or ban.</TD></TR></TABLE>
someone did it on his CRX lkess then a month ago. I remember seeing it and there were pics too I just cant go through the whole ordeal of finding it. Just remember to use creamy not chunky lol
Re: Nasty carbon fiber hood (StreetEG)
Peanut butter??? Please someone help me out I would seriously consider trying it if you now first hand of the outcome. Ya, I was actually just considering re-clear coatinhg it but figured there has got to be other ways first. I just went out and bought a buffer but have not tried it yet.
buffing it will work but for only a short time...also, someone did posted up something about peanut butter and that will work too...My friend wet sand his and buffed then sprayed clear coat on it like 3 yrs ago and it is still shiny til today. so which ever u perfer.
Re: (Mr Si_Vtec)
Well the other way seems like to much of a hassle. Does the peanut butter only work for a short time or does it actually last. Also what exactly do i do. do i rub it on as if i were waxing it like instead of wax I just use peanut butter.
Re: (5genprelude)
and there is no way that peanut butter is going to replace that.It will help but for a very short period of time the only long lasting way is the clear coat method.All you do with the PB is just rub it all over and let it sit a little while so the oils seep in then wipe it off and clean the hood
Re: (siblues)
Ok then ill just get it reclearcoated would I be better off taking it to a place and have it redone or try it myself???
Re: (siblues)
Oh no man don't worry it's cool. I just saw somewhere bout people using a some sort of 3m products and wet sand sandpaper but yeah I'd prolly rather have someone else do it depending on how much they charge.
Here are some threads on how to fix your problem including a DIY on how to sand and reclear it.
https://honda-tech.com/zerothread?id=1630243
https://honda-tech.com/zerothread?id=1553533
https://honda-tech.com/zerothread?id=1535349
Also that 3M stuff that I spoke of before was 3M Marine Wax. Try that and see if it does anything.
Re: (5genprelude)
Peanut butter on my Fiber Images trunk..
Obviously it doesn't fix anything, it only hides it's oxidized shame... I've used the 3M Marine Polish to no avail, even with an industrial buffer it still didn't shine as good as the creamy Skippy made it...
Re: (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues »</TD></TR><TR><TD CLASS="quote">How long does the Skippy last and whats better Skippy or Jiff </TD></TR></TABLE>
From my experience I got a few weeks of being parked overnight and sitting outside during the day... Few days of rain, etc...
As far as brand, I have no idea... I just used whatever I had in my cubbard when I was trying it out on my seals, which it did work pretty decently on also...
The problem with peanut butter is it obviously goes on very thick... So you need to use a small amount at a time and massage it into and around a small area, and work in progressively larger and larger circles (wax on, wax off...)
Re: (5genprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5genprelude »</TD></TR><TR><TD CLASS="quote">Ok so on that pic which part is from the peanut butter top or bottom.</TD></TR></TABLE>
The top is what it looks like oxidized, the bottom is after 1 quick rub down of peanut butter...
