Window reset on 2007 Honda Accord
Re: Window reset on 2007 Honda Accord
I always use my scanner. Never had to do it manually. I just looked up the procedure. looks unnecessarily involved:
Without the HDS
Without the HDS
- Turn the ignition switch ON (II).
- Move the driver's window all the way down by using the driver's window DOWN switch.
- Open the driver's door.
- Turn the ignition switch OFF.
- Push and hold the driver's window DOWN switch.
- Release the driver's window DOWN switch.
- Repeat steps 4-7 three more times.
- Wait 1 second .
- Confirm that AUTO UP and AUTO DOWN do not work. If AUTO UP and DOWN work, go back to step 1.
- Move the driver's window all the way down by holding the driver's window DOWN switch to the AUTO DOWN position.
- Pull up and hold the driver's window UP switch to the AUTO UP position until the window reaches the fully closed position, then continue to hold the switch for 1 second .
- Confirm that the power window master switch is reset by using the driver's window AUTO UP and DOWN function. If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps
hondagal2004
11-27-2013 07:55 PM
TahitianEG
04-07-2011 11:50 AM
msnewman
11-09-2008 10:42 AM
