Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Image of 2003 sensor to reset srs
Old 05-23-2014, 09:13 AM
mikensu1234's Avatar
Default Image of 2003 sensor to reset srs
I searched all over and I found mostly images of civics.
I have a 2003 accord and I am trying to reset the srs light so that the light goes off.
Can Anybody post that image??
Old 05-23-2014, 10:38 AM
DCFIVER's Avatar
Default Re: Image of 2003 sensor to reset srs
I believe you need a scan tool....
Old 05-23-2014, 11:42 AM
Global Moderator
tech8's Avatar
Reset can be done with a scan tool or manually with the MES connector.
The Memory Erase Signal (MES) connector is at the under-dash fuse/relay box. It is a 2P yellow connector with one wire being LT GRN/BLK or BLU; and the other wire BLK or BRN.
Old 05-23-2014, 03:24 PM
DCFIVER's Avatar
I know it can be done on 2002 and down,but i have not seen anyone do it on an 03 and up. Have you done it tech8 ?
Old 05-23-2014, 03:45 PM
Global Moderator
tech8's Avatar
I have a scan tool. The MES connector is still on the 7th gen Accords (2003-2007); that image is from the Honda ETM. The instructions for manual reset is in the service manual.
Starting with the 8th gen Accords, they no longer had the MES connector.
Old 05-23-2014, 04:59 PM
BLKFLSH's Avatar
I used it to turn off the SRS light in my 03 Accord. This car will display codes all over the place, without the need for a scan tool. I got MICU codes to display in the odometer screen. I figured I would buy a scan tool, if I ever needed one for this car, but 11 years later, and I haven't needed a tool yet.
Old 05-23-2014, 06:10 PM
DCFIVER's Avatar
Originally Posted by tech8
I have a scan tool.
As do I ,an MVCI,which is why I was unaware if the procedure could still be done manually.
Good to know.
Old 05-23-2014, 06:12 PM
DCFIVER's Avatar
Codes are not the reason to buy a scan tool. Thats what a code puller is for. You buy a scan tool for the datastream it provides. This is a tremendous help in diagnosing faults,whether there is a dtc or not.
Janet1995
10-08-2010 09:41 PM
chrishuns
11-15-2007 07:20 PM
Teg4e
06-22-2006 01:10 PM
LSVTEC408
01-02-2003 12:52 AM
Adam G
10-25-2001 03:13 PM
Quick Reply: Image of 2003 sensor to reset srs
