Old 03-25-2015, 10:57 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
93 Accord SRS Light reset.
Old 11-13-2007, 09:54 AM
chrishuns's Avatar
Default 93 Accord SRS Light reset.
I have seen the other posts on srs light resets under the accord section but have seen nothing for the 4th gen Accord. My light is on and I would like to reset it to see if that solves the problem. I have seen the yellow connector on the front of my fuse box. and seen the instructions for attempting a reset of 5th and 6th gen. If it is the same, the only questions I have about those instruction are "should I unplug the connector from the fuse box when I'm attempting the reset, and I have seen some say dont use jumper/paper clip and others say it worked for them using a paperclip." What method works, I would like to not pop off my airbag.
Thanks in advance for any help!
Old 11-13-2007, 07:08 PM
dtapia's Avatar
Default Re: 93 Accord SRS Light reset. (chrishuns)
the srs light came on fora reason most likley a failed srs control unit or open reel cable have it checked out.
Old 11-14-2007, 02:16 PM
chrishuns's Avatar
Default Re: 93 Accord SRS Light reset. (dtapia)
Thats prob the next step. I wanted to try a reset since that worked for many others and I'm not sure why the light is on since it was on when i bought it.
Old 11-14-2007, 03:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrishuns &raquo;</TD></TR><TR><TD CLASS="quote">Thats prob the next step. I wanted to try a reset since that worked for many others and I'm not sure why the light is on since it was on when i bought it. </TD></TR></TABLE>
You can check the code by jumping the service check connector. You'll have to dig up the procedure to clear the light using the mes connector.
Old 11-15-2007, 12:13 PM
josephcitr's Avatar
1993 has no resest procedure if there is no problem light will be out most 1993 that come into the shop need the drivers air bag and cable reel..............
good luck
Old 11-15-2007, 12:16 PM
josephcitr's Avatar
they have no self diag or trouble codes it wasnt an opp. unit the 1994 accord which doesnt make sense do the fact that civics had self diag in 1992
Old 11-15-2007, 05:46 PM
chrishuns's Avatar
Default Re: 93 Accord SRS Light reset. (josephcitr)
any clue what that would cost me to have it done at a shop? and with it the way it is now will the airbag not deploy in an accident? also is the service beyond a handymans capabilities? thanks for the responses!
Old 11-15-2007, 07:20 PM
radiuslight's Avatar
sounds right
My car was in an accident with the previous owner
My light is also on but not always
sometimes it goes on and sometimes it stays off
sometimes it goes on when I make turns
I just gave up on it.....not a problem here
PaulRi
12-08-2015 05:29 PM
kornerk12
11-10-2008 04:11 PM
M0nK3e.StyLeZ
06-22-2006 07:33 PM
cd5_2NR
01-28-2003 05:19 AM
97V6ACCORD
11-17-2002 06:26 PM
Quick Reply: 93 Accord SRS Light reset.
