Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Engine shuts off while driving. No check engine light, starts back up, no codes?
Old 01-08-2023, 06:35 AM
juicebox619?'s Avatar
Default Engine shuts off while driving. No check engine light, starts back up, no codes?
Hello!
Weird problem, twice yesterday my Mothers 06 just shut off. First just after going over a speed bump in a parking lot so maybe 10mph at best. It immediately was able to be restarted with no symptoms.
About 10 miles later driving down a residential street coming to the corner to turn (I don't know if she was at a stop or just coasting to the stop, but she says, all the dash lights turned off except the headlight green light. Again no issue starting up.
What I checked:
1) Battery is relatively new, it tested at 12.5 volts
2) New alternator, tested at 13.90 volts
3) No check engine light
4) I used my inexpensive scan tool and no codes or faults to report.
I followed her home with no issues.
I read Fuel pump could be an issue, but if the fuel pump shut off, would the speedometer, and other dash indicators go black (this was at night)? I wasn't driving it so the symptoms are second hand.She has no issues accelerating. over 1/4 on the fuel,
Any thought what to check?
Thanks
Max
Old 01-09-2023, 07:55 AM
DCFIVER's Avatar
Default Re: Engine shuts off while driving. No check engine light, starts back up, no codes?
Try to vigorously move the battery cable ends.
They should not budge.....
Old 01-11-2023, 03:32 PM
Honda-Boomer's Avatar
I would check all fluids, oil and anti-freeze. There are sensors that trigger alarms. You might need an expensive scan tool to see those, probably a $700 one.
Old 01-11-2023, 03:35 PM
Thanks. I read it may be the Main Relay (fuel pump). I ordered one. I will check the fluids.
LSteggyguy
07-09-2014 06:42 PM
got_no_sol
Other Make Vehicles
13
07-05-2009 05:24 PM
j0sh
04-16-2007 06:54 PM
wreckedhatch
29
03-16-2006 06:46 PM
rad_thundercat
04-21-2004 08:20 PM
Quick Reply: Engine shuts off while driving. No check engine light, starts back up, no codes?
