Engine shuts off while driving. No check engine light, starts back up, no codes?
Hello!
Weird problem, twice yesterday my Mothers 06 just shut off. First just after going over a speed bump in a parking lot so maybe 10mph at best. It immediately was able to be restarted with no symptoms.
About 10 miles later driving down a residential street coming to the corner to turn (I don't know if she was at a stop or just coasting to the stop, but she says, all the dash lights turned off except the headlight green light. Again no issue starting up.
What I checked:
1) Battery is relatively new, it tested at 12.5 volts
2) New alternator, tested at 13.90 volts
3) No check engine light
4) I used my inexpensive scan tool and no codes or faults to report.
I followed her home with no issues.
I read Fuel pump could be an issue, but if the fuel pump shut off, would the speedometer, and other dash indicators go black (this was at night)? I wasn't driving it so the symptoms are second hand.She has no issues accelerating. over 1/4 on the fuel,
Any thought what to check?
Thanks
Max
What I checked:
Thanks
Max
Re: Engine shuts off while driving. No check engine light, starts back up, no codes?
Try to vigorously move the battery cable ends.
They should not budge.....
I would check all fluids, oil and anti-freeze. There are sensors that trigger alarms. You might need an expensive scan tool to see those, probably a $700 one.
Thanks. I read it may be the Main Relay (fuel pump). I ordered one. I will check the fluids.
wreckedhatch
29
03-16-2006 06:46 PM
rad_thundercat
04-21-2004 08:20 PM
