2012 tsx seat wiring help..with wiring diagrams
Not getting much action on drive accord so thought I'd try you guys here. I was a member a long time ago when I had my crx.
Anyways I'm trying to swap 2012 tsx special edition front seats into my 2012 coupe lxs. Pretty sure I've got the srs system figured out as well as the passenger seat power. My issue is the drivers seat with the memory control. The wiring for passenger seat is straightforward, +12v, switches, grounds. The problem I'm having with the driver seat is there are 5 wires running to each motor. The switch outputs the selection to the memory control unit which then relays it to the motors. I'm 99% positive I have to bypass the memory control module and wire the motors direct from the switches, just like the passenger seat. The other thing is the driver side motors contain position sensors. I believe that the obvious need for the extra wiring going to them. If I can determine which pins I need to use off the motors to wire direct to the switchesI should be good I've included diagrams so you can see what I've got. Any help or suggestions would be greatly appreciated.
Passenger seat:
Driver seat:
Continued driver side with switches :
Passenger seat:
Driver seat:
