Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord v6 key won't turn in ignition
Old 02-08-2015, 04:05 PM
wwzjd's Avatar
Default 2007 Accord v6 key won't turn in ignition
When the key is put in the ignition and attempted to be turn it will not turn similar to when the steering wheel needs to be turned for the lock cylinder to function. Is this a anti theft issue or is it a ignition lock cylinder problem? Car is in park, and the steering wheel is locked, but turning steering wheel does nothing. Key can only be stuck in, will not go to accessory or crank position.
Old 02-09-2015, 02:58 PM
Lost Again's Avatar
Default Re: 2007 Accord v6 key won't turn in ignition
Hard call but since you state the wheel is locked, see if you can get the key to turn as you gently turn the wheel side to side.
Old 02-10-2015, 11:41 AM
He knows where you live!
TheMuffinMan's Avatar
That is expected, try tugging on the wheel one way or the other and it should wiggle a bit and then let you turn the key.
Old 02-11-2015, 09:00 PM
Hobit's Avatar
I thinks there is an issue in its battery so it had not ignite properly.If there is any other issue so there is need of proper checkup of this car.So then we sort out it.Simply you can take it to mechanic he will know better about it.
jackl04
10-05-2021 03:09 PM
Alice Jones
Honda CR-V & Element
18
01-26-2018 03:30 PM
CNCProgrammer
Honda Civic (2006 - 2015)
12-15-2017 03:22 PM
maryk2121
06-25-2013 11:35 AM
jcivic96
08-24-2010 04:33 PM
Quick Reply: 2007 Accord v6 key won't turn in ignition
