2005 Accord Drain Tube Under Engine
I have a 2005 Honda Accord 4 door sedan. There is a small pool of fluid (not water but I am not sure if it is oil or another engine fluid) on the ground under the center of the engine. I felt above the pool & there is the open end of a rubber tube maybe a half inch across. There is fluid on the inside the tube that I can feel.
Does anyone know what I am talking about? I am trying to determine if the fluid is coming from that tube & if it is what is it & can I fix it or need to fix it. Any help would be appreciated. Thanks
Re: 2005 Accord Drain Tube Under Engine
The drain tube under the car is for the A/C condenser, which would be water that drains from it. If you ran the A/C for a while, you normally will see a pool of water on the ground after you park it for a while.
DoubleDoobie420
07-18-2017 05:42 AM
oddlaww
09-25-2008 06:54 AM
