2003 Honda Accord Cooling System problem
Hi all,
I have 2003 Honda Accord 4 Cylinder engine, it has a peculiar problem. One day i found the engine overheating problem, I replaced Thermostat, Water pump, Clean the cooling system hose, Clean the radiator . But still the engine was over heating, Finally i found water not flowing thru the thermostat. So i removed the thermostat valve from the mount and run the engine, running fine, with thermostat water was not circulating. I replaced the new water pump and tried still not working. I running the car well without thermostat.
Please some one share your experience this kind of problem.
Thanks,
Velu
Thanks,
Velu
