Turn Signal Problem
Turn Signal Problem
Hi guys,
I am having problem with left turn signal only. Right turn signal is working fine. I double checked both front and rear turn signal bulb, and I don't think it's a bulb issue.
Left turn signal won't light on the instrument panel either.
No click/ticking sound can be heard. Hazard light won't make any difference. Where should I begin to look for?
Could this be a problem from a turn signal switch or flasher relay?
Where is this flasher relay located?
If I need to replace any of those parts, can I find them in local pepboys or autozone?
Thanks in advance.
Thanks in advance.
ate my pixel
1 Post
Re: Turn Signal Problem (polaris80)
Probably not your flasher since only one of the signals is out. There's a short somewhere in the circuit for that turn signal sounds like. Start with the fuse and the connectors, go from there.
Re: Turn Signal Problem (accord2021)
Ahh..shoot..
I was hoping this would be a simple replacement of flasher relay.
While I searched on Google, the most cars have separate flasher relay for left and right side. Does anybody know where are the flasher relay located?
Phrog
01-31-2014 01:12 PM
