Timing Belt Question
I did my timing belt this weekend. After we started the car I have a pretty noticable whine coming from that area. When we were putting the balance belt on the tightening sequence didn't seem to tighten the belt. we could still spin the tensioner without the belt moving. so we ended up applying hand pressure and then tightening the adjusting bolt.
now i'm wondering if we overtightened it.
the helms manual does have a secton about adjustment without a total breakdown, but it doesn't tell you to take off the lower cover, which means i can't put the 6mm bolt to hold the timing belt tensioner.
By the way this is a 99 accord EX 4 cylinder.
one last question. did honda make a 99 4 cylinder DOHC?
Re: Timing Belt Question (jravensc)
hope you didnt leave the 6mm tension retaining bolt in there.
You can loosen the tension nut that is sticking thru the timing cover, then turn the crank 1/4 turn and retighten the tensioner nut.
The counterbalance belt doesn't need to be tight, it is driven by the cogs and belt teeth
Re: Timing Belt Question (hondadude)
Thanks for the reply. No, we removed the 6mm and reused it in the lower cover.
That is great news. I really think we did overtighten the balance belt. It looked crazy loose but I guess it was correct.
Thanks again
ps
any word on that DOHC accord?
Thanks again
ps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jravensc »</TD></TR><TR><TD CLASS="quote">
any word on that DOHC accord?</TD></TR></TABLE>
no 99 DOHC accords were made. at least not in USA
H-T Order of Merit
sorry I wasn't able to respond to your PM over the weekend as I was busy and did not make it online.
I did respond to your PM earlier though
Re: Timing Belt Question (TouringAccord)
Hey civic, no the alt belt is o.k. The noise is definately coming from the inside the timing/balance belt region.
No worries Touring, I appreciate you taking the time to respond. I will try to make the adjustment soon and let you guys know if all is well.
Good news, I did the adjustment and it fixed the problem. No more noise = no more me closing my eyes and rubbing my temples at every stop light. Thanks for your help guys.
marymiller29456
Classic Hondas
10-31-2012 12:03 PM
