Tec advise
I own 1990 Accrod LX. The fan on it blows hot air only. It does not change the temperature if I turn it down or up. What might be wrong with it? Thank you. Please help!!!!!!! It is too hot!!!!!!!
Modified by Myroslav at 7:54 AM 5/9/2005 |
Re: Tec advise (Myroslav)
On a 1990 accord I would say check to make sure that the knob isn't broken. If it is when you turn it nothing is happenign. If the knob is good either the hot water valve is stuck or the cable that opens and closes it is stuck.
do you mean a/c not working???
Re: Tec advise (Turbowa)
thanx, gonna check after work
Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">do you mean a/c not working???</TD></TR></TABLE>
It does not have A/C |
I WOULD FOLLOW TURBOWA ADVICE.....IF THE KNOB IS OK,,,GET SOME VISE GRIP AND SQUUEzE THE INLET HOSE TO THE HEATER VALVE IF IT STARTS COOLING A BIT HEATER VALVE IS STUCK OPEN
Re: (Myroslav)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Myroslav »</TD></TR><TR><TD CLASS="quote">
It does not have A/C</TD></TR></TABLE> Start with the knob then we'll go from there. |
