Speedometer issue
Old Mar 30, 2008 | 07:32 PM
ShelbyX3's Avatar
Default Speedometer issue
1995 Accord EX ... the speedo works when its warm inside the car but not when its cold. Like all this week it worked while going to work in the afternoon. But when I get out of work at 3AM it doesn't work for the 16 mile ride back home. It doesn't have a check engine light or anything on. The tach works fine also.
Would this be the VSS or the guage cluster itself??? The VSS is $100 at advance auto and I haven't really looked for a cluster yet. Please help with my issue. Cause I really don't want to buy parts I don't ne
Old Mar 30, 2008 | 07:38 PM
TheMuffinMan's Avatar
He knows where you live!
Cluster itself, do a search, it's a common problem.
You can either buy a working cluster and swap the IC on the back of the speedo or solder the points back together and go that route.
Old Mar 30, 2008 | 07:43 PM
hondadude's Avatar
Default Re: Speedometer issue (ShelbyX3)
Normally if the VSS is the problem you will get a CEL code.
Your description leads me to think of a bad connection in the cluster or a poor solder joint.
FWIW
The speedo uses a digital to analog converter, to change the VSS digital pulses to an analog signal so it operates the speedo needle smoothly.
Old Apr 4, 2008 | 09:53 AM
ShelbyX3's Avatar
Default Re: Speedometer issue (hondadude)
Thanks for the info. I will try to find another cluster.
ryrex02
Dec 7, 2010 08:45 AM
d_EG COUPE
14
Apr 10, 2009 01:15 PM
hondaboy4life
Oct 9, 2006 09:35 AM
turbo Si
Jul 9, 2006 07:12 PM
EK SQUAD 425
May 10, 2006 03:28 AM
