speedometer
Old May 12, 2013 | 01:40 PM
JoshuaM07's Avatar
Default speedometer
hey, my speedometer isnt working. i need a speedometer schematic. anyone know where i can get one?
way it is now i have no speed reading or odometer. i have three different clusters all work but not in the car. two vss, one new and one used. both work. checked wiring and i have power all the way to the gauge cluster. just one wire has continuity in a few pins. thinking there is a resistor somewhere or something.
Old May 12, 2013 | 01:54 PM
92 civic ex 4dr's Avatar
Im not sure where madmike and ghostaccord get their schematics from. But before anyone WILL help you. You will need to provide, year, model, sub model, engine and Trans type. Otherwise for all we know your looking for the schematic for a 1970 chevelle
Posted from Honda-tech.com App for Android
Old May 12, 2013 | 05:16 PM
JoshuaM07's Avatar
Default Re: speedometer
its a 97 honda accord se f22b2 manual
Old May 13, 2013 | 05:35 PM
Lost Again's Avatar
I've got a '66 Chevelle....does that count ?
OP- the 5th gen's have an issue with the speedo/odo.
Did the cruise control work at anytime - don't take this the wrong way but you have 4 posts.....so I can assume you just got the car?
You say you have three clusters and they all work? How is/was that verified?
What testing have you done from the three wires on the vss to the cluster>
Old May 13, 2013 | 10:58 PM
JoshuaM07's Avatar
Na, I have had the car sense 2004. Back when cruise control was on it, it worked fine. I have tested continuity on all three to the end of their destinations. Also lifted the car and did the wheel check with it rolling to verify vss worked properly. Also I have three different clusters from junkyards. One worked fine, drove the car around the yard before I pulled the cluster. I found a schematic finally and also found out the ground could be week. Friend of mine civic did the same and he spliced in an extra ground and It worked. Gonna try that next
[713]
Mar 9, 2010 05:15 PM
puSSy
Nov 29, 2009 09:31 PM
JDM Dylan
14
Mar 5, 2008 09:11 PM
NegativeXero
Aug 22, 2006 08:32 AM
CarreraGT2E
Apr 7, 2003 10:24 PM
