Possible problems with headlights
Old Jan 17, 2004 | 06:27 AM
DSayavan's Avatar
Default Possible problems with headlights
Hey everyone,
I just bought a 91 Accord EX and am having problems with the headlights. Whenever the car is running and I turn on the lights, they don't turn on right away. I counted one time and it took as long as 15 seconds! When the car is off the lights will come on right away. Does anybody have any ideas? I'm going to go get the alternator tested today. Any help would be appreciated.
Old Jan 17, 2004 | 10:29 AM
DSayavan's Avatar
Default Re: Possible problems with headlights (DSayavan)
anybody??
Old Jan 17, 2004 | 12:03 PM
TypeRKoncepts's Avatar
i would say find out about the alternator...
Old Jan 20, 2004 | 06:17 PM
DSayavan's Avatar
Default Re: (TypeRKoncepts)
Well I haven't had time to get the alternator checked. But now I noticed that the lights delay coming on even when the car's not even on. So that couldn't be the alternator could it? Could it be a headlight relay? Any help would be appreciated.
Old Jan 20, 2004 | 06:18 PM
The_Todd's Avatar
Farts in the shower
Default Re: (DSayavan)
Could be a faulty switch or bad relay.
Old Jan 20, 2004 | 06:21 PM
mwkirchner's Avatar
If I had to guess ... I would say you need to replace the headlight switch. Over the years the contacts will wear and it sounds like they are not making contact right away.
Old Jan 21, 2004 | 08:51 AM
DSayavan's Avatar
Default Re: (mwkirchner)
If it is the switch, how hard is that to do? Will I have to pull that whole assembly from the steering column? Or does the end just come off? Thanks everybody.
Old Jan 21, 2004 | 09:00 AM
The_Todd's Avatar
Farts in the shower
Yes take off the top and bottom valances and it should be right there.
http://www.hondaautomotivepart...WITCH
here is a detailed look at the switch and connections.
Old Jan 21, 2004 | 09:12 AM
.bagged's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Yes take off the top and bottom valances and it should be right there.
here is a detailed look at the switch and connections.</TD></TR></TABLE>
Check the grounds too...if you have a faulty ground problems can occur...
Old Jan 21, 2004 | 09:17 AM
The_Todd's Avatar
Farts in the shower
Default Re: (bagged93accord)
Also you may want to check your actual plug to your bulb....sounds dumb but sometimes the easiest way is overlooked
Old Jan 21, 2004 | 04:40 PM
DSayavan's Avatar
Thanks for all your help guys. I'm going to try to take a look at that this weekend.
XGlite015
Jul 18, 2012 01:36 AM
lilmarcEH3
Jan 28, 2010 04:29 PM
BLUTO
Lighting
Oct 27, 2007 02:11 PM
90Kaccord
Oct 14, 2005 11:41 PM
b18cEF9
Jan 27, 2005 03:35 PM
