part name or number of window motor driver's side?
Old 07-30-2011, 04:25 AM
steveare's Avatar
Icon2 part name or number of window motor driver's side?
sometime last spring every window in my '97 honda accord 4-door stopped working except for the driver's window. mechanic said it'd cost me $84 just to take off the driver's side door panel to look at it but suggested i go to a local parts garden (junkyard) where they tell me the help would find the part i needed, take off the panel and replace the part and if it worked, i'd pay. if it didn't, i wouldn't. anybody know what the name or part number might be for the motor or switch that's burnt-out?
Old 07-30-2011, 08:20 AM
poorman212's Avatar
Default Re: part name or number of window motor driver's side?
So are you needing the "master" switch? A few quick tests will confirm.
Old 07-30-2011, 12:30 PM
steveare's Avatar
Icon2 Re: part name or number of window motor driver's side?
see, i don't know what it's called. all 3 passenger windows quit working at the same time. i got in the car, turned the key, hit the auto-roll down on the driver's window, went to roll the others down, nada on the others. thank god they quit working when they were up. just the driver's side window has kept working. i thought it could be a fuse under the hood or something but the mechanic says no, says it could be the window-motor or the master switch or something. so yeah, it could be the master switch, like i know what that means.
Old 07-31-2011, 03:25 AM
poorman212's Avatar
Do you have a volt meter and willing to pull the switch for testing?
Old 07-31-2011, 03:42 AM
steveare's Avatar
my mechanic does. i wouldn't know how to get at the thing w'out damaging the door. any good sources for manuals on this sorta thing?
Old 07-31-2011, 05:37 AM
poorman212's Avatar
You can search for video's and manuals....
google can be a friend.....didn't watch all of this, just the first one I came across.
http://www.youtube.com/watch?v=0_Z8lE5zC0o
Old 07-31-2011, 06:33 AM
steveare's Avatar
Thanks, Poorman. Btw, I meant to get back to you (and several others) who attempted to help me a while back over the oil leak near the oil filter? You won't believe this but the situation resolved itself on its own somehow. After having had to keep adding oil a quart at a time while I was getting suggestions about what to do about it, it stopped leaking. Go figger.
Old 07-31-2011, 07:06 AM
poorman212's Avatar
No problem, I replied to your other thread on this issue before I was this one.....
einzelherz
12-16-2011 02:58 PM
marks97el
12-27-2010 08:49 AM
TRYLSTEG808
03-03-2008 05:55 PM
acketon
07-02-2006 11:01 PM
berge
04-02-2006 09:59 PM
Quick Reply: part name or number of window motor driver's side?
