Odometer Problem and key ignition problem
Old Sep 14, 2005 | 06:31 AM
jokestar's Avatar
Default Odometer Problem and key ignition problem
Well i'm new here, just want to say hello to everyone and see if you can help me with my problems
1994 accord ex 2.2L vtech
Problem 1:
my odometer just quit working, it stopped at 90202 and will not work any further
Problem 2:
My key will not come out of the ignition, nor will it move to "0"
Would appreciate any suggestions
thanks
justin
Old Sep 14, 2005 | 07:37 AM
Slunk's Avatar
Default Re: Odometer Problem and key ignition problem (jokestar)
The odometer problem is pretty common from what I have gathered on the 5th gen accords. Mine went out at 22k and the dealership replaced it.
Old Sep 14, 2005 | 07:42 AM
jokestar's Avatar
Default Re: Odometer Problem and key ignition problem (f22b2power)
ill have to have that checked out if there isnt another way to fix it
any clue on the ignition probem?
Old Sep 14, 2005 | 08:04 AM
Slunk's Avatar
Auto or manual transmission? I would also advise you to search the archives here at HT I am sure this topic has already been covered by people who know a lot more than me.
Old Sep 14, 2005 | 08:16 AM
Papoose's Avatar
i had a problem with key stuck in ignition on 96 ex, however it was not the factory key it was a duplicated piece of **** that my 15 year old nephew decided he should try on his uncle's car. little bastard (literally.... LOL)
cost me 90 bucks to have a specialized locksmith come and get it out of there. took him about half and hour of playing with it. i was puzzled why it wouldn't go back to "0" and i'm also worried for you, especially if your key is the factory honda key from the dealer. good luck pal.
Old Sep 14, 2005 | 08:30 AM
jokestar's Avatar
its automatic
and there is a CHIP connected to i dont know what in the transmission and i have tried removing that and trying to take the key out but that does not work
and it is actually he correct key and it starts fine with it, i just cant take it out and it could be easily stolen :\
Old Sep 17, 2005 | 08:41 AM
blindman's Avatar
Speed o is probably bad. I had the same prob in a 1994 Accord. Replaced the speed sensor and that did not help. My speed o stuck at 20mph and worked some time. The inst cluster may be hard to get out.
Old Sep 17, 2005 | 03:03 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jokestar &raquo;</TD></TR><TR><TD CLASS="quote">
Problem 2:
Does the "P" light on the dash come on when the shifter is in park?
Old Sep 17, 2005 | 09:02 PM
deserthonda's Avatar
problem # 1 ,,most likely it is the v.s.sensor ..but u should confirm it before u waste ur money in a new 1 ..i have seen a few wiring problems and a few gauges go bad as well........
# 2 , make sure u are all the way in park like it was suggested ,if it will come off , go to a dealer and have them cut a new key and try it , or if u have another key try it with it ............ if key still wont come off get pliers and gently pull on key ..u might have bad tumblers in the ignition switch ,,,,,,,,,,make sure steering wheel is not fully locked to 1 position ,,in other words move the steering wheel and see if it helps
Old Sep 18, 2005 | 01:49 AM
rival12's Avatar
Default Re: Odometer Problem and key ignition problem (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">
# 2 , make sure u are all the way in park like it was suggested ,if it will come off , go to a dealer and have them cut a new key and try it , or if u have another key try it with it ............ if key still wont come off get pliers and gently pull on key ..u might have bad tumblers in the ignition switch ,,,,,,,,,,make sure steering wheel is not fully locked to 1 position ,,in other words move the steering wheel and see if it helps</TD></TR></TABLE>
i had a problem with my ignition switch, when the contacts burnt out my speedometer did not work.
Old Sep 18, 2005 | 09:35 AM
Juccord's Avatar
Default Re: Odometer Problem and key ignition problem (rival12)
Your shifter is not stuck in park, its a safety thing, if you really need to get it out, there are wires leading to a conector in your steering column, right at the wheel, normally you can see them when you look under the wheel, just unplug those and it will come out. Thats what I had to do..
Outlaw-Hondaz
Mar 18, 2011 12:24 PM
4gencivicef9
Honda Civic (2001 - 2005)
Feb 16, 2008 09:13 PM
ClayM
Mar 9, 2004 07:47 PM
deviant94ex
Jan 2, 2002 05:30 PM
