how to unclip the wire harness 2000 accord
Hello -
I'm trying to get to the coolant temperature sensor, it's right below the distributor.
There is a plastic wire harness that's in the way, and I've been unable to
figure out how to pull it off of the bracket it's attached to.
Anybody know the secret ?
Thanks
Thanks
Re: how to unclip the wire harness 2000 accord
If you look closely to where the black plastic harness looms attach to metal clip posts there are tabs that need to be pressed as you pull up on the loom. The hardness itself can be difficult to move because there's not a lot of slack. thats it.
I still haven't figured it out. Here is an image of the harness in question. As can be seen, it's
attached on it's right hand side to the bracket. It seems as if it should slide to the back.
There is a single tab, but my manipulation of it (so far) have not yielded any positive results.
wire harness attached to bracket
