Accord AWD conversion
Old 01-20-2019, 02:27 AM
Darkjesus75's Avatar
Default Accord AWD conversion
2001 accord awd conversion
I was just thinking about coverting to an awd set up on my accord that I have already done a jdm h22a swap in and was trying to get advice on this matter. Any suggestions?
My h22 swap
Old 01-21-2019, 01:18 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Accord AWD conversion
Generally, if you have to ask then it probably is not within your scope.
98-02 USDM Accords are CG bodies.
00-01 JDM AWD Accord SiR Wagons are CL bodies.
Find the diagrams and see how well related the rear suspensions are on the CG vs the CL.
CA-CE Accords are the similar suspension wise with a trailing arm.
CF-CL Accords used a multilink rear suspension.
Look up Bluetop AWD Sir Accord wagons, that will be your go to parts.
Old 01-21-2019, 02:45 PM
Thanks will look at it and see what's up when I get home from work
Rod VTEC
03-01-2009 07:30 AM
withoutshore
03-19-2007 08:20 AM
lamsv
02-18-2006 03:11 PM
Spoogen_1
12-16-2004 11:49 AM
Quick Reply: Accord AWD conversion
