How to: Compression Test.
Old Jun 3, 2009 | 08:52 AM
DxBurnoutKing's Avatar
Default How to: Compression Test.
Hey guys.. sorry if this has been posted already.. but I tried searching google High and Low.. and I flipped through the Sticky at the top of the page.
I'm trying to do a Compression test on my 1997 Acura 2.2 CL and I don't have the slightest clue as to HOW. I bought a Compression tester from Auto Zone yesterday.
If anyone could help me out.. I'd REALLY appreciate it.
I'd like to also take pictures while I do this so that maybe we can add this to the FAQ's at some point.
Thanks!
Old Jun 3, 2009 | 08:56 AM
whitewonder's Avatar
Default Re: How to: Compression Test.
disconnect dizzy power ....
take a spark plug out.
screw compression tester in spark plug hole.
make sure compression tester isnt in your belts......
crank car for 10 seconds. read compression.
put plug back in 15-20 ft lbs.
repeat for your other 3 cylinders.
Old Jun 3, 2009 | 09:02 AM
how do i disconnect power to the dizzy? just unplug it?
Old Jun 3, 2009 | 09:24 AM
yep ... just disconnect the connecter that runs into it. so its no receving any power.
Old Jun 3, 2009 | 12:06 PM
3zFree's Avatar
Better:
-Take ALL spark plugs out.
-Compression tester in the hole.
-Disable fuel injectors by unplugging them, or disconnect connector going to distributor up to you, preferably injectors.
-Have somebody crank the car AND hold gas pedal depressed, not doing this WILL GIVE YOU INCORRECT READINGS.
-Crank till you get a static pressure.
-Repeat for all cylinders.
-Pat yourself on the back and have a cold one.
Old May 8, 2013 | 06:25 AM
ricerodder91EX's Avatar
what ever turns the injectors off and is the easiest and quickest way is the best and WTF is a Dizzy? that has got to be the most annoying slang I've ever heard.
Isn't there a relay or fuse you can unplug?
Old May 8, 2013 | 07:22 AM
DeadlockRiff's Avatar
distributor = dizzy.
also yes you can pull fuses to disable the ignition and the fuel system, which fuses I cannot find out from my current locale.
Old May 8, 2013 | 12:56 PM
holmesnmanny's Avatar
you just need to pull the ecu fuse
Posted from Honda-tech.com App for Android
Old May 9, 2013 | 04:49 AM
I pulled two plugs on teh DISTRIBUTOR. didn't smell any fuels. got 190-180-170-190.
Old May 10, 2013 | 05:50 AM
faran's Avatar
Just did it recently by pulling the ECU fuse, might help someone as well:
Old May 11, 2013 | 01:02 AM
this doesn't disable fuel tho
NegativeXero
11
Aug 18, 2006 06:52 PM
iHOPEyouCHOKE
Apr 27, 2006 04:44 PM
iHOPEyouCHOKE
Apr 21, 2006 06:40 AM
danny98r
May 18, 2005 12:31 PM
BlackB18CTeg
Mar 24, 2003 08:44 PM
