Timing belt - screwed up balance shaft
Old 06-24-2017, 11:36 AM
tobytigger's Avatar
Default Timing belt - screwed up balance shaft
I had a senior moment during timing belt replacement on '98 2.3L and forgot to remove a hex key I used to lock the rear balance shaft. I had the new timing and balancer belts installed and was turning the crankshaft one turn counterclockwise after everything was looking good. But after about 1/4 turn I figured out the hex key was still in access hole. After panicking I tried to pull the hex key out but it was jammed, so I barely turned the crank to free up the hex out and it snapped in half. Pulled out the long piece and it looked like it broke cleanly. I used a small magnet pickup and got the broken piece out. Both the long piece and the broken piece still look straight. The balance shaft is turning freely.
Last night I removed the belts and started over with the timing belt. Aligned the camshaft and crank TDC marks with no problem but after the timing belt was installed when I checked TDC it looked like the camshaft timing marks were off by 1/16. Today removed the timing belt and tried to set TDC on camshaft and think I'm in big trouble. I can turn the camshaft about 1/3 turn and it binds up. If I use slight force to turn the camshaft it feels like something is hitting and will not budge so I stop. Any ideas how bad this could be and what the fix is if any besides the junk yard? The crank shaft is turning smoothly.
Old 06-24-2017, 03:20 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Timing belt - screwed up balance shaft
If the crank is at or near TDC then the valves are making contact with the piston tops when you turn the camshaft. F series are interference engines.
Rotate crank 90° from TDC and you will be able to spin the camshaft with no interference problems.
Old 06-27-2017, 10:54 AM
tobytigger's Avatar
Thanks Mike - looks like we still have an engine.
Ef4doorwagon
17
08-30-2014 11:58 PM
delsolboi
03-13-2013 11:57 AM
ashb82
03-18-2010 04:04 PM
Rost
07-03-2009 09:51 PM
yosuthnmasa
04-08-2008 07:29 AM
Quick Reply: Timing belt - screwed up balance shaft
