help! oil pressure sensor f22b2
i need help finding where to put my aftermarket oil pressure sensor. i found a place on the block but nobody anywhere makes a fitting help. please email shabbaspeedn@yahoo.com thanks.
Re: help! oil pressure sensor f22b2
http://www.autometer.com/cat_accesso...il.aspx?vid=59
part #2269
Use this adapter and buy a 1/8" NPT tee fitting with male on one end, female on the other, and female on the side. The stock oil switch is BSPT thread (British) so you have to adapt the tee fitting to the block where the oil switch is, then attach the sensor and the stock switch to the tee. The stock switch is BSPT, but with some teflon tape, it will seal when threaded into the NPT tee fitting. i never could find a BSPT tee. Don't overdo it with the tape or your oil light may not work anymore since it may not ground properly. Email me if you have any questions about it. I did this a couple years ago on my f22b2.
part #2269
gsr96cx
12-23-2010 07:09 PM
pelotudo
08-18-2002 06:31 PM
NikoZai
08-12-2002 06:39 AM
