Please identify this Switch/sensor !!!
Old Oct 6, 2013 | 03:45 PM
M-benz's Avatar
Default Please identify this Switch/sensor !!!
Guys,
I'm trying to search for the name of this switch ..the one I'm pointing with screw driver. As you can see it is next to the little one coolant temp sensor . Can anyone help ? I don't think it is an oil pressure switch . When I unplugged that there were two terminals inside . Again , I have 00 Tegg GS 2drs ( stock motor / manual )
Old Oct 6, 2013 | 04:26 PM
sirtef9's Avatar
Default Re: Please identify this Switch/sensor !!!
oil pressure switch
Old Oct 6, 2013 | 04:35 PM
M-benz's Avatar
I told Autozone , Napa & Pepboys they all gave me the one that in the back of the block next to oil filter . Any ideas ?
Old Oct 6, 2013 | 05:15 PM
B_Swapped93's Avatar
Lol at false info given...nope that's the ECT sensor why do you need to know nad the little one is the "dash sending unit"
Old Oct 6, 2013 | 06:07 PM
M-benz's Avatar
I thought little one is called the coolant temp sensor ??? That's what I just replaced !!!
Old Oct 6, 2013 | 06:09 PM
M-benz's Avatar
So I guess the one replaced in the back of the block next to the oil filter is the oil sending unit and my GS doesn't have the oil pressure switch then ?
Old Oct 6, 2013 | 06:13 PM
zachhthe1's Avatar
B_swapped is right. One on the side odnthe head is for guage signal. Thenothernone by the thermostat housing is an ECU ground. Check the ground net to it for corrosion.
Old Oct 6, 2013 | 06:29 PM
M-benz's Avatar
Ok let me just summarize it ...we have 3 switches/sensors for coolant system ? One is called thermo fan switch located on thermostat housing , second is the little/skinny one called coolant temp sensor and the 3rd one would be the sending unit which I'm looking for from my pic shown above ???? Can anyone confirm ? Please use the exact terms or words ...
Old Oct 6, 2013 | 06:48 PM
1st correct
2nd, nope "dash sending unit" is the little single wire black one
3rd is what your screwdriver is pointing to in the pic and is known as the ECT sensor.
Old Oct 6, 2013 | 06:50 PM
M-benz's Avatar
I will stop by pepboys Tmorrow and ask for ECT sensor see what they say or give me lol ...
OK !!! Back to the oil sensor/switch . I already replaced the one in the back of the block next to the oil filter ...I'm calling that one " Oil Sending unit " correct ? And where is my oil pressure switch ?
Old Oct 7, 2013 | 12:11 PM
M-benz's Avatar
Anyone ?
Old Oct 7, 2013 | 12:26 PM
tamboo's Avatar
10 Year Member
not seeing any other switch/sensor for oil, just that one:
http://www.rockauto.com/catalog/x,ca...,parttype,4588
Old Oct 7, 2013 | 12:42 PM
M-benz's Avatar
Ok I guess the one I replaced in the back of the block is called Oil Pressure Switch and I don't have the Sending unit one ...hmm ...
Old Oct 7, 2013 | 06:44 PM
grjr's Avatar
The sensor near the oil filter is an oil pressure switch for the idiot light in the dash. There is no oil pressure sender because these cars do not have an oil pressure gauge.
Old Oct 7, 2013 | 07:06 PM
The thing you're pointing to in the pic has nothing to do with oil...just sayin.
Old Oct 8, 2013 | 04:56 AM
M-benz's Avatar
Thank you !!! I guess I'm all set now
Jaz760
Mar 15, 2011 04:41 PM
shabba
May 20, 2010 09:48 AM
ctownintegra
Mar 5, 2007 05:02 PM
NikoZai
Aug 12, 2002 06:39 AM
