Heating system isn't heating up that good
Old 10-06-2003, 08:03 PM
Milton90accord's Avatar
Default Heating system isn't heating up that good
When i put the heat on in the my 1990 honda accord the heat doesn't warm up that well if feels cool not hot.
Old 10-07-2003, 10:49 AM
JimBlake's Avatar
Default Re: Heating system isn't heating up that good (Milton90accord)
Lotsa possibilities...
If your temperature gauge is reading normal, then look for a broken/disconnected cable from your control lever to the heater valve, air bubbles in your heater core, or even a kinked heater hose in the engine compartment. Maybe corrosion/crud in your heater core, but then it would probably be in your radiator too (causing overheating).
If your temperature gauge is reading real cool, the thermostat might be stuck open. So the coolant never gets hot.
Old 10-10-2003, 04:02 AM
93CivicSI's Avatar
Flush your cooling system - and install new thermostat - antifreeze / water 50/50 -
Old 10-10-2003, 04:11 AM
KGAccord's Avatar
Default Re: Heating system isn't heating up that good (93CivicSI)
i would check the cable the for the heater ****.
i have next to no heat too, when i turn the **** full hot it springs back to about 2/3 hot.
jackhis
06-18-2022 10:26 PM
raider1qaz
02-17-2013 01:52 PM
dantamparacer
08-05-2010 06:51 PM
nucrxowner
01-18-2005 12:52 PM
topher
02-02-2002 06:41 AM
Quick Reply: Heating system isn't heating up that good
