Grinding noise while crusing
Old Oct 8, 2004 | 01:39 PM
my97accord's Avatar
Default Grinding noise while crusing
I hear a mild grinding noise when I take my foot off the gas pedal while crusing, it stays for few seconds and goes away when I step on the gas pedal. It is not very loud, not sure from where it is comming I guess somewhere from the front passenger side.
Any thoughts?
Old Oct 8, 2004 | 01:44 PM
my97accord's Avatar
Default Re: Grinding noise while crusing (my97accord)
It is a 4-Cy LX with auto tranny.
Old Oct 8, 2004 | 01:46 PM
KatyHonda's Avatar
Check the drive shafts for clearance and signs of rubbing. Check the brake calipers for secure bolts and brake pads.
If you have a 2.2L 4-cyl., I have had the harmonic balancer grind through the timing belt cover on my 90 Accord EX. Not sure why, perhaps increased crankshaft end play, but it might be sensitive to power input. It will be real difficult to check this because the clearance of the balancer/pulley is very tight to the timing belt cover. You will have to pull the wheel and check carefully w/ mirror.
good luck
ooosorio
Honda Civic (2001 - 2005)
Sep 17, 2016 01:11 AM
hondahugger
Dec 1, 2009 07:43 PM
the_lude_01
Mar 24, 2009 03:46 PM
94gsr_vtc
Nov 24, 2004 03:45 PM
oldbeefcake
Aug 24, 2004 03:09 AM
