Old 03-25-2015, 11:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
GAS SMELL IN CABIN!!!
Old 01-06-2012, 12:24 AM
da93integra's Avatar
Icon2 GAS SMELL IN CABIN!!!
Hey HT heads,
I got a quick question about my 96 Accord EX...
HELP ME STOP GETTING HIGH OFF OF GAS FUMES, PLEASEEEE!!!
I just got it about 2 weeks ago and I can't seem to find out what's the problem. I'm getting gas vapors inside the car. I took it to the muffler shop and replaced the muffler and resonator, put in new NGK Spark plugs, EGR valve (Auto) and cleaned the injectors. I was thinking the charcoal canister or fuel filter, or maybe even the cat converter... If any of you have had this problem and might know a solution, (other than dropping the tank, or replacing the fuel filter) let me know ASAP... If you need more info, let me know! ALSO, NO PRESSURE FROM GAS TANK FILLER HOLE... REPLACED CAP A WEEK AGO, STILL GOT THE PROBLEM...
96 Accord EX
F22B1 SOHC V-Tec Engine
Bone Stock
Exhaust mani heat shield still intact... (might be the ex mani?) Let me know!
Thanks in advance!
-DA93INTEGRA <------ My first love! haha
Old 01-06-2012, 01:32 AM
jdmcertified909's Avatar
Default Re: GAS SMELL IN CABIN!!!
where is it the strongest. in the front or the back? leave your windows open same with the doors. after a while go and sniff out the car. try to see where it is the strongest
Originally Posted by da93integra
Hey HT heads,
96 Accord EX
Bone Stock
Thanks in advance!
Old 01-06-2012, 03:30 AM
djkurious's Avatar
Has there been anything installed under the drivers seat?
Old 01-06-2012, 04:06 AM
Not that I know of. The car did have a system installed before I got it. It has to be coming in from the outside because if I have the windows up, the smell doesn't come in. If I have my sunroof open and windows down, it starts to smell like a gas station. The smell is sick!
ALSO: I AM NOT GETTING ANY PRESSURE FROM MY FILLER CAP... I REPLACED THE CAP A WEEK AGO, BUT TO NO AVAIL... I DO NOT HAVE PRESSURE COMING FROM MY GAS TANK!!!
Old 01-06-2012, 04:12 AM
@ jdm, the funny thing is the car has to be rolling to get the strong smell. But if I had to pick a place where it's the strongest, I would have to say the front passenger area... My girl has to smell her shirt when I drive.
Old 01-06-2012, 04:30 AM
djkurious's Avatar
Check the fuel lines, see if they are wet with gasoline. They run from drivers side to the rear in a cage like holder.
Old 01-06-2012, 05:48 AM
oc9979's Avatar
My wagon had the same issue. I checked the fuel lines and nothing. It was the bolt/screw that it is in the bottom of the fuel tank. It wasn't tight all the way.
Old 01-06-2012, 06:26 AM
I'll check the lines asap... As for the bolt, i never thought of that. It does smell like fuel when i pop the trunk... I will try that n report back n let u guys know... Thank u for ur speedy responses!
Old 01-06-2012, 06:08 PM
bb4ninja's Avatar
Any luck ?
Old 01-06-2012, 09:01 PM
motegicivic's Avatar
Take off the heat shield on the exhaust mani to see if it cracked.
Let the car run look under the hood see if you see any fuel leaks, check the fuel filter first, check the fuel rail, it is under a lot of pressure you will see it.
Check the fuel pump, if it like civics pull up the back seat and see if you see anything.
Worst case, you might have to pull the gas tank to see if it is cracked (unlikely)
Old 01-07-2012, 07:05 PM
AndyD's Avatar
I had the same problem. Turned out to be the fuel lines being rusted up near rhe gas tank. Driver's side. There's a plastic cover.
Do you notice and gas on the ground when the car's parked?
da93integra
08-28-2012 03:45 PM
TsunamiHair
01-28-2009 05:11 PM
b16gurl
04-17-2006 05:10 AM
aeongap
07-25-2005 07:41 PM
NiBlazed
10-26-2004 07:07 PM
Quick Reply: GAS SMELL IN CABIN!!!
