Engine sputtering even when driving.
Old Sep 29, 2014 | 05:00 PM
onunezp's Avatar
Default Engine sputtering even when driving.
Hello HT
im having an issue with my 94 accord, the engine is sputtering a lot (sometimes), even when im driving, i accelerate and it sounds like the engine is shooting with an AK 47, when idle, same thing, it sounds like an old car.
i bought a fuel filter but im not sure if that is the problem, yesterday i cleaned EGR valve and ports, this issue only happens sometimes, not always, any ideas?
Old Sep 30, 2014 | 03:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Engine sputtering even when driving.
Pull the plugs check for wear and gap, check the wires, check the cap/rotor.
If you have no record of when they were changed, change them.
Old Sep 30, 2014 | 08:11 PM
onunezp's Avatar
Thank you, i will, its good to have an idea,
i took off my dist cap and it has a lot of corrosion,
will change those parts.
I have a question, can install a simple fuel filter in my car? deleting banjo bolt and all that stuff and use it with clamps?
Old Oct 3, 2014 | 04:33 PM
onunezp's Avatar
can i install this filter on my accord, deleting banjo bolt and such?
Old Oct 4, 2014 | 10:00 AM
filthycannibal's Avatar
Keep an eye out while in the distributor for that pesky ignition control module. It has three or two attachment screws and sits just below the rotor with three or four wire attachments with an attached heatsink. Some of those wires may be corroded and dry rotted. That c*** will start acting up and cause similar problems at least beyond 3000k and cut off intermittently in my experience. Don't buy a cheap one if that's the source of your problem. Its worth it to spend the extra cash. Ive had cheap ones go out in 3 mos. Napa ones are pretty reliable. Something worth a check.
Old Oct 4, 2014 | 08:37 PM
onunezp's Avatar
i bought the cap and rotor and installed them, i labeled the wires position but someone told me they were incorrect, can you send me a picture of the correct firing order?
another thing, one of my cables is not firing, so i have to buy the cables,
thanks in advance
Old Oct 5, 2014 | 08:16 AM
holmesnmanny's Avatar
1-3-4-2 starting in the bottom left
Old Oct 5, 2014 | 01:10 PM
onunezp's Avatar
thnk you holmesnmanny, thats what i needed,
i fixed the wires issue, but i have another one, i think i screwed the ignition timing when i was trying to remove the rotor, because the car drives like hell, a lot of stuttering even at high rpms, i also made this test: with the car on, i unplugged the wires leading to the plugs, one by one, i they made a change in idle, except in plug #3, no change when unplugged, so i think i have a wire issue.
one cylinder not working can result in a huge loss of power and stuttering? or did i messed up the ignition timing?
Old Oct 5, 2014 | 04:41 PM
MAD_MIKE's Avatar
MM Gruppe B
One cylinder on a four is 1/4 power gone. Yes it will affect power output.
Old Oct 5, 2014 | 04:48 PM
U need to compression test
Old Oct 7, 2014 | 05:00 PM
onunezp's Avatar
thank you, so i changed cap, rotor and wires, still the same problem, when i disconnect the plug, in cylinders 1,2 and 4, the car almost stalls, number 3, no change, i suppose my cylinder is gone, what is the next step? how this can be fixed? i have no idea, im going to take it to a mechanic but i want to know,
thank you
Old Oct 7, 2014 | 07:47 PM
onunezp's Avatar
UPDATE: so i found this post Part 1 -How to Find a BAD Fuel Injector (Case Study)
and i swapped my injectors, and all works perfect now, spark is good, idk wth, but its good , thank you for your help.
rocky2005
Aug 10, 2011 05:58 PM
spyda man
Aug 21, 2007 09:31 AM
vietkangta
Jul 28, 2007 12:43 AM
94accord1985
Feb 25, 2004 07:42 AM
Sam5
Feb 18, 2003 01:18 PM
