engine mount
Old Aug 14, 2003 | 05:36 PM
david90's Avatar
Default engine mount
I have two manuals, haynes and chilton. Chilton says to replace the 3 engine mount bolt with 3 new ones when removing them and haynes didn't say jack about replacing them. Should I replace it? my manual contradic and i want to do the job right!
Old Aug 14, 2003 | 05:38 PM
bill-71SS's Avatar
Default Re: engine mount (david90)
no need to replace bolts
Old Aug 14, 2003 | 05:48 PM
Stripped Honda's Avatar
99-0104
Default Re: engine mount (bill-71SS)
dont change the bolts there isnt that much stress on them but just look at them to see if there is any damage on them if not then just install the old ones
Old Aug 15, 2003 | 01:42 AM
david90's Avatar
Is there a trick that will make sure my mount line up before I put the bolt in? I'm afriad of cross threading it.
Old Aug 15, 2003 | 08:11 AM
Nick M's Avatar
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a trick that will make sure my mount line up before I put the bolt in? I'm afriad of cross threading it.</TD></TR></TABLE>
no tricks
Old Aug 15, 2003 | 03:24 PM
Superorb's Avatar
theres no way around it, its a bitch to do the front mount, so just wiggle it around and pray, it too kme almost an hour for the 1st one, and i had someone wiggling the motor. u can also unbolt the brac ket from the block and wiggle just the mount and bracket, but good luck.
hondachris1994
10
Nov 22, 2006 05:42 PM
Crimson_Tide
Jul 20, 2005 07:40 AM
GapxGuy
Aug 24, 2004 09:41 PM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
litlekikr
May 12, 2003 05:30 PM
