EGR problem... HELP!
Old 02-06-2006, 09:21 AM
XiOus271's Avatar
Default EGR problem... HELP!
ok, i was coming home from school today and my CEL came on, so i had the code read, it was p1491 EGR valve lift insufficient. i have a 2000 accord dx. my question is what do i need to do to fix this, and are there any problems that could arrise from this if i cannot get it fixed soon? thanks!
Old 02-06-2006, 10:06 AM
kulrevon's Avatar
Default Re: EGR problem... HELP! (XiOus271)
you can take off the egr valve and clean it see if that helps. if it doesnt you are going to have to clean the egr passageways. which depending on the manifold there are different ways to do it.
do you know if you have the removeable rail on the top of the intake runners if so you are in luck. take it off and clean the egr.
if you dont have the removable rail you either have to pull out the plugs/ or drill. or use a liquid (seafoam/intake cleaner) and pour it into the passageways.
hope some of this helps and doesnt screw you up.
Old 02-06-2006, 12:09 PM
amckee's Avatar
The EGR valve itself has a position indicator sitting directly on top of it that measure how far the valve has moved. If you are getting a CEL then either
#1 The valve is stuck so the sensor doesn't see it move
#2 The EGR vacuum line is off or leaking
#3 The solinoid that enables vacuum to the EGR isn't working
#4 Vacuum line that runs from the plenum to the solinoid is off or leaking
Old 02-06-2006, 01:34 PM
XiOus271's Avatar
Default Re: EGR problem... HELP! (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">you can take off the egr valve and clean it see if that helps. if it doesnt you are going to have to clean the egr passageways. which depending on the manifold there are different ways to do it.
hope some of this helps and doesnt screw you up.</TD></TR></TABLE>
im not too sure, but im going to have my family look at it and see what can be done from there. thanks for the advice!
knaup109
07-08-2017 04:01 PM
xrider01
01-27-2009 05:24 PM
jose310
01-08-2009 09:35 AM
mtn_biker_lpw
06-09-2007 11:18 AM
Quick Reply: EGR problem... HELP!
