Codes
Old Jan 29, 2015 | 07:37 PM
mydreamc5's Avatar
Default Codes
Hi! I am new to the forum and fairly new to working on Hondas. I have a 2002 Honda Accord with a 4 cyl. The other day it would not start easily. After it did finally start it ran extremly rough and died. Check engine light was on. I pulled up a code P0108 map sensor. I bought a new sensor and replaced it. The car started fine, took it for a test drive amd while on my test drive after it warmed up (about 3 miles) the check engine light came back on. I went home, and pulled the code P0131. My concern is there is something else wrong besides changing out every sensor in this car. Anybody have any ideas or thoughts? Thanks in advance!
Old Jan 29, 2015 | 08:28 PM
Treyschls's Avatar
Default Re: Codes
The higher the engine vacuum, the lower the voltage reading. The voltage should range between about 1 volt (at idle) to about 5 volts (WOT wide open throttle).
If the PCM sees the voltage reading from the MAP sensor is greater than 5 Volts, or if the voltage reading is higher than what the PCM considers normal under certain circumstances, a P0108 DTC will set.
Potential causes of a P0108 code:
•Bad MAP sensor
•Leak in vacuum supply line to MAP sensor
•Engine vacuum leak
•Short on signal wire to PCM
•Short on reference voltage wire from PCM
•Open in ground circuit to MAP
•Worn engine causing low vacuum
Found this on obd-codes.com
I say check the wiring harness at the map sensor all the way to the ecu.... If you look behind the sensor clip on the wiring harness the wires in the back could be loose or broken
ALSO MAKE SURE YOU WRITE DOWN ALL THE CODES BEFORE YOU CLEAR CHECK ENGINE LIGHT!
SO YOU KNOW ALL YOUR PROBLEMS...
Old Feb 2, 2015 | 07:10 AM
mydreamc5's Avatar
Default Re: Codes
Thanks! I will check all this out and see what I come up with!
chucky86
Oct 13, 2011 02:46 PM
dkray944
Dec 9, 2008 07:53 PM
ProjectTib
Apr 28, 2007 08:11 AM
Stevegunit16
10
Feb 14, 2007 07:21 PM
TheIceMan
Dec 5, 2005 10:44 AM
