Check engine light with header
Old Feb 2, 2007 | 07:41 AM
YipMan_Style's Avatar
Default Check engine light with header
A guy a work was thinking about getting a header for his 06 Accord EX. Another guy said if you do, the check engine light will come one. Is this true?
I don't have an Accord, or a header so I don't know.
Thanks
Old Feb 2, 2007 | 08:42 AM
philadd's Avatar
Default Re: Check engine light with header (YipMan_Style)
As long as you reinstall the O2 sensor you shouldn't get a CEL. And I assume this is on a 4-cyl, since you can't get headers for the V6...
Old Feb 2, 2007 | 09:24 AM
Default Re: Check engine light with header (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">As long as you reinstall the O2 sensor you shouldn't get a CEL. And I assume this is on a 4-cyl, since you can't get headers for the V6...</TD></TR></TABLE>
Yeah, it's a 4 cylinder. Does pretty much all aftermarket headers have a place to put the O2 sensor back?
I heard this came up because one guys said you have to "ghetto sim" it to fake the system. Not sure what that means.
Old Feb 2, 2007 | 09:27 AM
khunt0012's Avatar
Meat Robot Invisible
He probably means something to simulate an O2 sensor, which BTW is not a very good idea.
Old Feb 6, 2007 | 05:17 AM
Default Re: Check engine light with header (khunt0012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khunt0012 &raquo;</TD></TR><TR><TD CLASS="quote">He probably means something to simulate an O2 sensor, which BTW is not a very good idea.</TD></TR></TABLE>
why not?
Old Feb 6, 2007 | 06:49 AM
JimBlake's Avatar
The front O2 sensor (the one in the manifold) is used to fine-tune the fuel/air mixture. Without it, it runs rich; & eliminating it (simulating it) doesn't really help performance anyway.
Most headers have a fitting in the proper place to install the sensor, so why not use it?
Old Feb 6, 2007 | 07:08 AM
Default Re: Check engine light with header (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The front O2 sensor (the one in the manifold) is used to fine-tune the fuel/air mixture. Without it, it runs rich; & eliminating it (simulating it) doesn't really help performance anyway.
I see. Thanks.
Old Feb 6, 2007 | 10:00 AM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YipMan_Style &raquo;</TD></TR><TR><TD CLASS="quote">
why not?</TD></TR></TABLE>sending a dummy voltage, just makes the ecu thing everything is alright... all the time.
busha61067
Feb 23, 2010 12:42 PM
ricanzxrebel
May 11, 2007 10:08 PM
2.0fiend
Honda Civic (2006 - 2015)
15
Nov 20, 2006 07:50 AM
tcbn
Mar 10, 2006 01:25 AM
KuG
29
Jan 19, 2002 08:36 PM
