Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
DC HEADER MODIFICATION
Old Aug 20, 2006 | 10:29 PM
2.0fiend's Avatar
Default DC HEADER MODIFICATION
I was just wondering if the DC header needed to be modified in any way when being installed. I heard that the O2 sensor bung needs to be welded on, just wondering. Thanks!!
Old Aug 21, 2006 | 10:31 AM
SickSpd06Si's Avatar
Default Re: DC HEADER MODIFICATION (2.0fiend)
my O2 sensor is making my check engine light stay on. did I not put the sensors back in correct or is it just going to be that way regardless of what I do. the check engine light wasn't on originally but it came on about 50 miles after the install
Old Aug 21, 2006 | 11:21 AM
Miracle's Avatar
Default Re: DC HEADER MODIFICATION (SickSpd06Si)
You need to buy an o2 simulator to eliminate the check engine light. Either that or jimmy rig the o2 farther away from the exhaust stream to avoid the CEL.
Old Aug 21, 2006 | 12:19 PM
AlabasterSI's Avatar
If you check on Ephatch.com and go to resourses they have a quick easy and cheap way to fix the check engine light my friend did it and it worked. Good Luck
Old Aug 22, 2006 | 07:46 AM
Default Re: DC HEADER MODIFICATION (AlabasterSI)
thanks alot man. I'm going to try this tonight hopefully. after i rig it. what should I do to get to CEL to go off? hey 2.0friend, everything for the header came in the box with the header and there was no welding needed. The only thing you'll need to do is rid the second o2 sensor so your check engine light isn't on all the time.
Old Nov 10, 2006 | 09:04 PM
95GSRBOI's Avatar
I thought you can just drive the car 2 cycles where the ecu reads it and it will reset itself.
Old Nov 12, 2006 | 02:08 PM
jonness's Avatar
I got a dc race header. I got this o2 simulator
and used that to avoid the check light from going
on. I got the simulator from my mechanic.
The checklight hasn't come on and its been about
a month.
Old Nov 12, 2006 | 08:54 PM
wcriot's Avatar
Wait a min. you are replacing your o2 sensor that is on the header with an o2 simulator?
Isn't this a big NO NO? does the DME read and decide the a/f ratio based on this o2 sensor?
An o2 simulator is basically a resistor that simply sends the signal that the o2 sensor is present. The sime will not monitor EGT which is why i ask about the effects of running the simulator?
Old Nov 12, 2006 | 09:02 PM
barroomhero's Avatar
Default Re: (wcriot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wcriot &raquo;</TD></TR><TR><TD CLASS="quote">Wait a min. you are replacing your o2 sensor that is on the header with an o2 simulator?
An o2 simulator is basically a resistor that simply sends the signal that the o2 sensor is present. The sime will not monitor EGT which is why i ask about the effects of running the simulator?</TD></TR></TABLE>
I believe what they are talking about is a threaded bung that goes between the o2bung on the header, and the o2sensor. Thus keeping it away from direct airflow from the exhaust. It will still be able to do its thing and sense a/f's its just taking it out of the direct path of the exhaust
Old Nov 13, 2006 | 07:26 AM
jkocr2's Avatar
Default your fix
http://www.k-series.com/forum/...=8833
Old Nov 13, 2006 | 03:15 PM
Blk06Si's Avatar
Ey AlabasterSI what kind of car did your friend say the part was for? Or is it universal?
Thanks
Old Nov 14, 2006 | 06:37 PM
teknoracing's Avatar
Default Re: DC HEADER MODIFICATION (ar3drum187)
Run a few spacers on the 02 sensor bung and you shoud be good for that. Never had a problem on my VW doing it.
Old Nov 15, 2006 | 05:49 AM
jkocr2's Avatar
follow the link i posted just up a few, i followed it step by step and i have an 06 si. trust me it works, oh and this is a universal part, i found them at autozone
Old Nov 15, 2006 | 04:32 PM
Blk06Si's Avatar
Default Re: (jkocr2)
Alright I just bought it today at autozone and installed it already. It was installed at 14,810 miles. I hope the CEL stays off. Thanks for your link jkocr2.
Old Nov 17, 2006 | 04:22 AM
Blk06Si's Avatar
Default Re: (ar3drum187)
Alright one more question about this header. What is the piping size? 2.25 or 2.5? I need to know so I can get a Cut-Out. Thanks in advanced
Old Nov 20, 2006 | 07:50 AM
jkocr2's Avatar
i believe it's 2.5"
ricanzxrebel
May 11, 2007 10:08 PM
Bravenrace
35
Sep 8, 2006 09:33 AM
tcbn
Mar 10, 2006 01:25 AM
supapoopa
19
Nov 14, 2005 03:46 PM
KuG
29
Jan 19, 2002 08:36 PM
