sensor
Old Feb 22, 2010 | 08:09 PM
busha61067's Avatar
Default sensor
i have a 94 accord ex and on my headers ther is a spot for a o2 sensor or something. it is blocked off with bolt but i was jw if there is supposed to a sensor there if so what kind and is it effecting anything thanks
Old Feb 22, 2010 | 08:29 PM
hollums2k's Avatar
Default Re: sensor
could be for an upstream o2 sensor..are you having any problems with the car? any check engine light? pass emissions? if its not broken dont fix it
Old Feb 22, 2010 | 10:17 PM
more3688's Avatar
Default Re: sensor
yes its a spot for a o2 sensor......if your not throwing a CEL then its prolly no big deal.....but i would definatly look into getting one hooked up if it was my car
Old Feb 22, 2010 | 11:20 PM
19Accord97's Avatar
Default Re: sensor
It is technically called a header.
I would get that checked out. On your year of Accord, the o2 sensor tells how much fuel to put in the cylinder. If it runs to lean it will be bad news. So either the previous owner unplugged the CEL light or rigged it up somehow.
Hows the mpg and running?
Old Feb 23, 2010 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: sensor
Your car should have 1 sensor before the catalytic converter. Look under the car and see if there is one there. If there is you are fine. Some aftermarket headers have a spot for two because on some models the O2 is higher up on the exhaust manifold so it gives you options on where to place it.
Old Feb 23, 2010 | 06:36 AM
GhostAccord's Avatar
Default Re: sensor
^x2
94-95 OBD1 Accords only have 1 O2 sensor and it is located on the bottom of the header pipe close to the catalytic converter. The 96-97 OBD2 Accords have 2 O2 sensors. One of them is up in the primary tube, as you are describing. And the other is behind the catalytic converter.
You have a 94, therefore you only have 1 O2 sensor and you do not need to use the upper O2 bung. You have to have at least 1 O2 sensor so as long as you have one before the cat somewhere your good.
Old Feb 23, 2010 | 12:42 PM
busha61067's Avatar
Default Re: sensor
ill check and see if i have one before the cat. thanks
dakuda
Jun 3, 2007 08:40 PM
coolrahool
Mar 25, 2005 11:06 PM
conguero
Nov 14, 2004 03:40 PM
Nizzy
May 22, 2003 03:58 PM
