Changing oil pan gasket on 97 EX?
Old 03-31-2005, 04:31 AM
vabchaccord's Avatar
Default Changing oil pan gasket on 97 EX?
Any procedures anywhere on this? Pictures? Special tools/advice/tips needed?
Old 03-31-2005, 04:40 AM
THEROPE's Avatar
Default Re: Changing oil pan gasket on 97 EX? (vabchaccord)
buy a helms for like 10 bucks at pepboys
you will need a range of sockets from 14mm to 10mm
drain the oil
take off your exhaust manifold
drop the oil pan like it says in the book
put the new gasket on
replace oil pan
replace manifold
change your oil filter and add some new oil and your set
Old 03-31-2005, 07:07 AM
Turbowa's Avatar
Default Re: Changing oil pan gasket on 97 EX? (THEROPE)
Ok, lets back up a little. First you can't buy a helms at pep boys. Your thinking of a haynes. Second leave the exhaust manifold on and just take the front lower exhaust pipe off ( A- pipe). You will also want to pick up some Hondabond. use this to seal the pan gsket to the pan and again to the bottom of the block. While you have the pan of go a head and clean it out with brake cleaner to make sure any old forgein material gets out.
Old 03-31-2005, 10:33 AM
Default Re: Changing oil pan gasket on 97 EX? (Turbowa)
Where can I get the Hondabond at? Does it just come in a tube?
Old 03-31-2005, 01:52 PM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get the Hondabond at? Does it just come in a tube?</TD></TR></TABLE>
dealership, yes it comes in a tube but its pretty expensive, hondaautomotiveparts.com may be able to get it cheaper, try giving them a call
Old 03-31-2005, 03:40 PM
JDM4DRACCORD's Avatar
is not expensive, it is hella cheap.
Old 04-01-2005, 04:58 PM
Toldge's Avatar
and use plenty of it too....i didn't use enough and ended up having to do the whole thing again a year later
Old 04-02-2005, 04:57 AM
Default Re: (Toldge)
I see listings for Hondabond 4 and Hondabond HT. Which one do I need?
Old 04-02-2005, 10:54 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toldge &raquo;</TD></TR><TR><TD CLASS="quote">and use plenty of it too....i didn't use enough and ended up having to do the whole thing again a year later</TD></TR></TABLE>
enough is enough, too much silicone or honda bond will taper the seat/sealing surface.
if there's a oil pan gasket availble for your year of accord, i wouldn't even use any liquid gasket in a tube.(sidenote 98-02 accord doesn't even have a oil pan gasket.)
Old 04-02-2005, 03:30 PM
jb.
jb.'s Avatar
Default Re: (iam7head)
i had a leaking gasket on my 95, and I replaced it with a carquest one, which didnt work, then one from a dealer, but it doesnt work like it should either. I scrubbed down the metal, completely cleaned the pan, and used some gasket sealer to stick the rubber to the pan, but it didnt work right, so i dont know how much of a help hondabond is compared to other sealers
free_money
10-21-2014 08:33 PM
Dj Skidz7
14
01-14-2011 05:36 AM
jdmwojo
12
02-01-2010 08:34 PM
ronald55555
04-19-2005 03:03 PM
ragejed
07-01-2002 01:15 AM
Quick Reply: Changing oil pan gasket on 97 EX?
