Changing oil pan gasket on 97 EX?
Any procedures anywhere on this? Pictures? Special tools/advice/tips needed?
Re: Changing oil pan gasket on 97 EX? (vabchaccord)
buy a helms for like 10 bucks at pepboys
you will need a range of sockets from 14mm to 10mm drain the oil take off your exhaust manifold drop the oil pan like it says in the book put the new gasket on replace oil pan replace manifold change your oil filter and add some new oil and your set |
Re: Changing oil pan gasket on 97 EX? (THEROPE)
Ok, lets back up a little. First you can't buy a helms at pep boys. Your thinking of a haynes. Second leave the exhaust manifold on and just take the front lower exhaust pipe off ( A- pipe). You will also want to pick up some Hondabond. use this to seal the pan gsket to the pan and again to the bottom of the block. While you have the pan of go a head and clean it out with brake cleaner to make sure any old forgein material gets out.
Re: Changing oil pan gasket on 97 EX? (Turbowa)
Where can I get the Hondabond at? Does it just come in a tube?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord »</TD></TR><TR><TD CLASS="quote">Where can I get the Hondabond at? Does it just come in a tube?</TD></TR></TABLE>
dealership, yes it comes in a tube but its pretty expensive, hondaautomotiveparts.com may be able to get it cheaper, try giving them a call |
is not expensive, it is hella cheap.
and use plenty of it too....i didn't use enough and ended up having to do the whole thing again a year later
Re: (Toldge)
I see listings for Hondabond 4 and Hondabond HT. Which one do I need?
Re: (Toldge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toldge »</TD></TR><TR><TD CLASS="quote">and use plenty of it too....i didn't use enough and ended up having to do the whole thing again a year later</TD></TR></TABLE>
enough is enough, too much silicone or honda bond will taper the seat/sealing surface. if there's a oil pan gasket availble for your year of accord, i wouldn't even use any liquid gasket in a tube.(sidenote 98-02 accord doesn't even have a oil pan gasket.) |
Re: (iam7head)
i had a leaking gasket on my 95, and I replaced it with a carquest one, which didnt work, then one from a dealer, but it doesnt work like it should either. I scrubbed down the metal, completely cleaned the pan, and used some gasket sealer to stick the rubber to the pan, but it didnt work right, so i dont know how much of a help hondabond is compared to other sealers
