Braking problem
Old Apr 27, 2003 | 06:39 PM
sacredc0w69's Avatar
Default Braking problem
Hey, i drive a 4th gen 1990 accord
in teh winter every once in a while when i pushed on the brake to stop the brake would just continuie to move in until it reached thefloor
on warm sunny summer daysit happens every time i try to brake
it just moves straight down into the floor, yes it does stop but i have to really push down be4 it hits the floor so i can stop on time or i have to realease and push the brake again...any ideas on whats wrong and what i should do 2 fix it?
Old Apr 27, 2003 | 06:41 PM
-RedneckDave-'s Avatar
Working
Default Re: Braking problem (sacredc0w69)
Check the brake fluid level.
Old Apr 27, 2003 | 06:43 PM
Default Re: Braking problem (01accordv6)
sorry i aint the best with cars i'm tring to learn what i can and i've been experimenting and working with friends and such
how do i check the brake lvl fluid?
wherecan i check it?
Old Apr 27, 2003 | 07:24 PM
BB6-00's Avatar
u might have a leaking caliper or wheel cylinder.
Old Apr 27, 2003 | 10:11 PM
FREAKquency04's Avatar
check the calipers see if u have a hole within the rubber area if that checks out check your brake fluid levels
Old Apr 27, 2003 | 10:15 PM
AcCO12D95's Avatar
I have the same problem, it is the master cylinder that is bad.
Old Apr 28, 2003 | 04:18 AM
Stew Pidasso's Avatar
Default Re: (AcCO12D95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcCO12D95 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem, it is the master cylinder that is bad.
Correct
Old Apr 28, 2003 | 07:17 AM
biggs2.3's Avatar
you could just have water in the lines, not alot just a drop or 2 will cause the fluid to go bad. you might just need to bleed the brake lines and replace the fluid
Old Apr 28, 2003 | 01:43 PM
WuWarrior's Avatar
Bleed the brakes before you go replacing parts. 90% of the time, bleeding is the answer.
theazndog
Jul 28, 2009 12:44 PM
spintboy
17
Jan 3, 2008 08:49 AM
david
Oct 31, 2005 11:02 AM
hnz28sjz
Jul 30, 2005 04:50 AM
sacredc0w69
Apr 29, 2003 11:05 AM
