Blinker problem
Old Aug 25, 2005 | 04:55 PM
casmello's Avatar
Default Blinker problem
My right front and back blinker work fine, but they are blinking really fast like to tell me one is out but there both working fine. Any ideas?
Old Aug 25, 2005 | 08:19 PM
deserthonda's Avatar
Default Re: Blinker problem (casmello)
first off chk the bulbs .....u might have a bad 1
Old Aug 26, 2005 | 01:27 AM
goowakjai
Guest
Posts: n/a
Default Re: Blinker problem (deserthonda)
did this start happening after u changed a bulb? if so u myte have gotten a wrong one
Old Aug 26, 2005 | 05:41 AM
casmello's Avatar
nope, just started happening. I guess ill just replace the bulbs one by one
Old Aug 26, 2005 | 10:39 AM
MestizoRacer310's Avatar
Default Re: (casmello)
Might also be corrosion on the bulbs (and your bulbs might be fine)......make sure all connections are clean and corrosion free......if you don't have anything to clean corrosion with....use Coca Cola. Then use some dilectric(Sp?) or bulb grease from an auto supply store. It will help prevent corrosion from starting.
Old Aug 26, 2005 | 10:46 AM
accord917's Avatar
check your fuse also. I had the same problems a few months ago.
Old Aug 26, 2005 | 12:56 PM
Default Re: Blinker problem (accord917)
if it is a bad fuse the lite would not blink at all..it would get no power to complete the circuit
Old Aug 27, 2005 | 12:31 AM
goowakjai
Guest
Posts: n/a
Default Re: (MestizoRacer310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Might also be corrosion on the bulbs (and your bulbs might be fine)......make sure all connections are clean and corrosion free......if you don't have anything to clean corrosion with....use Coca Cola. Then use some dilectric(Sp?) or bulb grease from an auto supply store. It will help prevent corrosion from starting.</TD></TR></TABLE>
coca cola? is that like a lil trickj u learned around the shop?? sounds interesting, wut else can it do besides clean corrosion and quench thirst?=D
Old Aug 27, 2005 | 10:17 AM
Default Re: (goowakjai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">
coca cola? is that like a lil trickj u learned around the shop?? sounds interesting, wut else can it do besides clean corrosion and quench thirst?=D</TD></TR></TABLE>
Yup. It's true. Soda doesn't quench thirst.....it makes it worse. If you drnk a lot and you feel thirsty......that's why. I don't know why scientifically........but it is true that soda doesn't help your thirst.
And still.......it's interesting that people still would drink the stuff (me included) after finding out it cleans off corrosion. I use it more for cleaning batteries if I'm out of battery cleaner spray.
Old Aug 27, 2005 | 11:37 PM
goowakjai
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Yup. It's true. Soda doesn't quench thirst.....it makes it worse. If you drnk a lot and you feel thirsty......that's why. I don't know why scientifically........but it is true that soda doesn't help your thirst.
And still.......it's interesting that people still would drink the stuff (me included) after finding out it cleans off corrosion. I use it more for cleaning batteries if I'm out of battery cleaner spray.</TD></TR></TABLE>
it doesnt quench thirst becuz of all the sugar and caffeine it has in it....honda-tech has now become softdrink-tech =D
jasony0630
12
Apr 11, 2008 09:44 AM
patrickstar
Jan 28, 2008 02:53 AM
SyDuck
Aug 4, 2004 05:36 PM
gsr-2nr
Jul 18, 2004 04:53 PM
gsr-2nr
Jul 18, 2004 04:52 PM
